Ip block list
#1
I wish there was a easy way to block a specific ip-range
there usualy isps that up to no good so it would be realy nice to be able to stop there ips in a dns query
and thank you for the good work
#2
DNS only resolves names to IP addresses. The Pi-hole doesn’t block IP addresses, for that you need a firewall on the router.
#3
is it not possible to to stop certain ip it like:
whats *.com’s ip ->its 1.2.3.4 ->checking->No go ip-> drop
#4
If you have a list or a block of IP addresses that you do not want the clients to visit, then you can set up a blocking firewall at the router to prevent any traffic from going to those IP addresses. The Pi-hole doesn’t route or proxy any traffic so it wouldn’t be able to drop traffic to those IP addresses.
