L_B
October 29, 2023, 5:50pm
1
I just discovered the same problem.
For many devices pihole shows two ips (one mis not valid).
Details:
Pihole dhcp is not enabled
I use edgerouter with dnsmasq updating dns
I have verified on EdgeRouter that there is only one entry for dhcp lease.
I have flashed dns table on Pihole.
jfb
October 29, 2023, 6:36pm
2
Tools > Generate Debug Log
L_B
October 29, 2023, 6:52pm
3
Thank you for your reply.
This is another system that is used for work access. Therefore I won’t be able to post the logs.
However, I can look into the debug logs. Is there anything in particular I should be looking at?
Thanks !
jfb
October 29, 2023, 6:53pm
4
How is your Pi-hole configured to know the names of your network clients?
system
Closed
November 19, 2023, 6:54pm
5
