I have problems with my PiHole v6. I try to start the DHCP server (after moving from an RPi to Proxmox) and always get the message: “ Invalid configuration
dnsmasq: syntax check OK.”. also importing the configuration via teleporter gave the same error.
I have taken over the pihole.toml from the old Pihole. the DHCP starts without problems on the old Pi, but not on the new Proxmox Pihole. Of course I deactivated the old Pi beforehand.
I see the following messages in the ftl.log:
“2025-01-03 17:55:34.688 ERROR Error NTP client: Failed to adjust time during NTP sync: Insufficient permissions
2025-01-03 17:56:22.732 ERROR Cannot wait for dnsmasq test: No child process
2025-01-03 17:56:22.732 ERROR dnsmasq test failed with signal 4
2025-01-03 17:56:22.733 WARNING New dnsmasq configuration is not valid (dnsmasq: syntax check OK.), config remains unchanged
2025-01-03 17:56:22.733 WARNING API: Invalid configuration (dnsmasq: syntax check OK.)”
Translated with DeepL.com (free version)```
Has there been any development with this issue? Seeing the same problem on my end, also running Pi-hole in an LXC on Proxmox. Log output is similar when trying to start the DHCP server (verifying all other fields are correct):
2025-02-20 14:27:56.187 UTC [14825/T15128] ERROR: Cannot wait for dnsmasq test: No child process
2025-02-20 14:27:56.187 UTC [14825/T15128] ERROR: dnsmasq test failed with signal 2
2025-02-20 14:27:56.187 UTC [14825/T15128] WARNING: New dnsmasq configuration is not valid (dnsmasq: syntax check OK.), config remains unchanged
2025-02-20 14:27:56.187 UTC [14825/T15128] WARNING: API: Invalid configuration (dnsmasq: syntax check OK.)
I ended up moving the Pi-hole installation onto a VM instead of an LXC. All the issues resolved themselves (including NTP issues). When I get a moment I'd be happy to test the changes, I'd prefer to containerize if possible but I can afford the additional resource use at the moment.
