Internet not working when DHCP enabled
When DHCP is enabled on the Pi-Hole (and disabled on the router), internet pages do not load or load slow, also the router is not accessible by it's IP, when I disable the DHCP on the Pi-Hole and enable it back on the router, everything goes back to normal. I also installed unbound and pivpn (wireguard), but the problem is only happening when the DHCP is enabled on the Pi-Hole.
Raspberry Pi OS
Raspberry Pi 4
Internet becomes unavailable
https://tricorder.pi-hole.net/5gnrgdl6nf
Oh fuck the DHCP server is in the DHCP range, maybe this is the problem. I will test later, people using the internet right now...
It seemed to be working but after a while a get the same problem.
Pi-Hole address: 192.168.2.1 (static)
Router address: 192.168.2.254
I can regenerate a new debug if needed.
