Should be able to view the Settings page but not able to browse it.
I click on the Settings link on the left and I am met with an internal 500 error. I tried a repair, tried removing the settings.php file so the repair recreates it. No luck. Getting an error in the logs along the line of "Can't use function return value in write context" on line 14 in settings.php
Here is the error I see in the log. Maybe it helps or maybe its from the date() warning.
2017-08-13 08:46:06: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Fatal error: Can' t use function return value in write context in /var/www/html/admin/settings.php on line 14
