Pihole reliably resolves DNS requests without timeout.
Pihole intermittently stops resolving requests, causing ping timeouts an loss of internet access (or more clearly, SSID still broadcasts but I'm not able to browse anywhere).
Ping stats:
ping 8.8.8.8 -t
Pinging 8.8.8.8 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 8.8.8.8: bytes=32 time=14ms TTL=121
Reply from 8.8.8.8: bytes=32 time=17ms TTL=121
Reply from 8.8.8.8: bytes=32 time=27ms TTL=121
Reply from 8.8.8.8: bytes=32 time=13ms TTL=121
Reply from 8.8.8.8: bytes=32 time=32ms TTL=121
Reply from 8.8.8.8: bytes=32 time=12ms TTL=121
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 8.8.8.8: bytes=32 time=25ms TTL=121
Reply from 8.8.8.8: bytes=32 time=15ms TTL=121
Reply from 8.8.8.8: bytes=32 time=119ms TTL=121
Reply from 8.8.8.8: bytes=32 time=18ms TTL=121
Reply from 8.8.8.8: bytes=32 time=16ms TTL=121
This issue is happening frequently, although I haven't found a way to reproduce it.
Other notes:
I am using a Netgear R7000 with the DNS server set to only my pihole (192.168.1.31). DHCP is still being handled by the router, and I've assigned the pihole that IP address statically.
My pihole is wired directly into my router via ethernet, and as far as I can tell, WiFi is not enabled on the pihole.
zzoh20k7g3
