Interface setting
Hello together,
I have an questtion to the Interface setting.
I reinstalled my PiHole, because the recommend setting wasn't possible to Set.
My question ist now why is the setting"responed only on interface eth0" set AS Default after Installation and not the "recommend - allow only local requests" setting?
Thanks in advance
I think you are right. We changed the web interface but not the installer script.
We do export the listening interface to setupVars.conf
And then call the webscript
But do not set/export DNSMASQ_LISTENING
required
Thanks for your fast reply, But i'm not so good in Reading Scripts :grinning_face_with_smiling_eyes:
This means that the Installer script need to be updated?
Thanks in advance
https://github.com/pi-hole/pi-hole/pull/4509
