Intercept DNS ( DDWRT to PI-HOLE )
Hi
I would like to intercept DNS on my DDWRT router (192.168.2.1) and send it to PI-HOLE. Im using this IP tables firewall script :
WAN_IF=nvram get wan_iface
iptables -I FORWARD -i br0 -o tun1 -j ACCEPT
iptables -I FORWARD -i tun1 -o br0 -j ACCEPT
iptables -I INPUT -i tun1 -j REJECT
iptables -I FORWARD -i br0 -o $WAN_IF -j REJECT --reject-with icmp-host-prohibited
iptables -I FORWARD -i br0 -p tcp -o $WAN_IF -j REJECT --reject-with tcp-reset
iptables -I FORWARD -i br0 -p udp -o $WAN_IF -j REJECT --reject-with udp-reset
iptables -t nat -A POSTROUTING -o tun1 -j MASQUERADE
iptables -t nat -A PREROUTING -i br0 -s 192.168.2.101 -p tcp --dport 53 -j DNAT --to 192.168.2.149
iptables -t nat -A PREROUTING -i br0 -s 192.168.2.101 -p udp --dport 53 -j DNAT --to 192.168.2.149
According this client with 192.168.2.101 should be forwarded to 192.168.2.149 - this is OK, I can see DNS queries in PI-HOLE log => OK (forwarded)
Then query should go to upstream DNS (Google, etc) - everything seems to be OK, but Im receiving DNS request timed out...?
First 8 lines are defined for my VPN connection - they can be igored - result is the same using only these two lines :
As Im intercepting only one IP PC adress, it shoult not be in conflict with anything else, OR ? I have tried Listen on all interfaces , Listen on all interfaces, permit all origins, but nothing helps.
Seems like DDWRT problem ? Thanks for help !
I have already found one solution for this problem. After PREROUTING rules I had to add
iptables -t nat -A POSTROUTING -j MASQUERADE
Problem is that since then I can not see original IP adress of DNS request /all DNS requests comes from IP adress of router/ , but at least its working ... :wink:
as far as i have been able to find there is no way to force this behaviour AND have it appear from original clients IP the device doing the redirect will always show as the client for redirected requests
