Integrated Unbound from GUI
Integrated Unbound with GUI interaction (allowing Unbound to be installed via GUI (on demand) by the user.
Settings > DNS > Unbound 4/6 (Check or maybe Toggle)
This could also enable a task for updating root hints periodically.
Also, with so many preprogrammed choices for DNS Upstream now, maybe it is time to make toggles or a pull down? The current page section "Upstream DNS Servers" could now have each upstream with info/privacy suggestions about themselves.
As always please keep up the amazing work. Thank you for everything that everyone provides!
Note that a similar feature request to add integrated DNS over TLS was closed as out of scope.
Thanks for the heads up. This probably falls in the same boat then.
