I integrated pihole v5.x into homeassistant. It had a switch and some 14 entities in home assistant. The switch can turn on and off pihole, and the entities can show how many domains be blocked and other info.
I have upgraded pihole to v6.0 in my armbian server. And I reintegrated it into home assistant. But I found the switch and entities were all failed.
How to make pihole v6.0 work in homeassitant?
_[Replace this text with what you think should be happening. Please include as much detail as possible including, but not limited to:
-operating system. Armbian
-hardware]_Amlogic s905l3a cpu, tv-box
