Installing PiVPN and making relevant setting from the following link worked for vpn the last time I installed it:
https://marcstan.net/blog/2017/06/25/PiVPN-and-Pi-hole/
PiVPN install broke down pihole and changed interface value in 01-pihole.conf file.
ifconfig didn't show tun0 as one of the adapters.
pihole -a -i all - this command almost never works in attempt to trying to get tun0 to work
correcting the interface=xxxx value to ethernet adapter fixed it. however i also uninstalled pivpn
4rt4bzx5qc
pivpn config file shows DNS servers which I don't recognize. they're now in dnsmasq.conf file also. as shown below. is something wrong with these values?
Blockquote
advice need to correctly install pivpn and make it work.
it was working fine until i did an update to version3.3
