I´ve installed Pi-Hole on a Debian 9.5 VM (VMware) and after login to http://pi-hole-ip/admin there is only the loading symbol on the dashboard.
No data at all.
How can I solve this problem?
GERMAN
habe Pi-Hole als VM mit Debian 9.5 installiert und wenn ich http://IP-PI-HOLE/admin aufrufe zeigt er mir keine Daten im Dashboard an.
Nur das Lade-Symbol
When I do following commands there is still the same problem with the empty dashboard. sudo systemctl stop pihole-FTL.service
sudo rm -f /etc/pihole/pihole-FTL.db
sudo systemctl start pihole-FTL.service
And when I click on "Query Log" I get this error message
pi@noads:~ $ php -i | grep 'PHP Version\|json\|sqlite3'
PHP Version => 7.0.30-0+deb9u1
/etc/php/7.0/cli/conf.d/20-json.ini,
/etc/php/7.0/cli/conf.d/20-sqlite3.ini,
json
json support => enabled
json version => 1.4.0
sqlite3
sqlite3.extension_dir => no value => no value
Please wait 24 hours and then check the Dashboard again : In the Release Notes of version 4.0 or 3.3 there was a notice mentioned that you have to wait 24 hours first before any data appears!
