Able to ping www.google.com from Ubuntu 18.4.
Unable to resolve any DNS names but able to perfectly ping 8.8.8.8 & 8.8.4.4.
root@pizza:~# pihole uninstall
[?] Are you sure you would like to remove Pi-hole? [y/N] y
[✓] Root user check
[i] Existing PHP installation detected : PHP version 7.2.7-0ubuntu0.18.04.2
[i] Be sure to confirm if any dependencies should not be removed
[i] The following dependencies may have been added by the Pi-hole install:
apt-utils dialog debconf dhcpcd5 git iproute2 whiptail bc cron curl dnsutils iputils-ping lsof netcat psmisc sudo unzip wget idn2 sqlite3 libcap2-bin dns-root-data resolvconf lighttpd php7.2-common php7.2-cgi php7.2-sqlite3
[?] Do you wish to go through each dependency for removal? (Choosing No will leave all dependencies installed) [Y/n] Y
[?] Do you wish to remove apt-utils from your system? [Y/N] Y
[i] Removing apt-utils...
root@pizza:~#
root@pizza1:~# cat /var/log/pihole_debug-sanitized.log
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2018-09-12:23:27:00 debug log has been initialized.
[i] Core: v4.0 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.0-0-gddbdb51
[i] Web: v4.0 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.0-0-gaf8c926
[✓] FTL: v4.0 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
*** [ DIAGNOSING ]: dnsmasq version
[i] 2.79
[i] 1.4.45
[i] 7.2.7
[✓] Ubuntu 18.04.1 LTS
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[i] x86_64
[✓] IPv4 address(es) bound to the eno1 interface:
192.168.1.201/24 matches the IP found in /etc/pihole/setupVars.conf
[✓] IPv6 address(es) bound to the eno1 interface:
fe80::94de:5c1a:33ba:8939 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
* Pinging 192.168.1.1...
[✓] Gateway responded.
*:111 rpcbind (IPv4)
*:111 rpcbind (IPv6)
*:80 lighttpd (IPv4)
*:80 lighttpd (IPv6)
*:22 sshd (IPv4)
*:8181 python (IPv4)
[✗] Failed to resolve wmedia.rotator.hadj7.adjuggler.net via localhost (127.0.0.1)
[✗] Failed to resolve wmedia.rotator.hadj7.adjuggler.net via Pi-hole (192.168.1.201)
[✓] doubleclick.com is 108.177.122.113 via a remote, public DNS server (8.8.8.8)
[✗] dnsmasq daemon is inactive
[✓] lighttpd daemon is active
PIHOLE_INTERFACE=eno1
IPV4_ADDRESS=192.168.1.201/24
IPV6_ADDRESS=
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
TEMPERATUREUNIT=F
WEBUIBOXEDLAYOUT=boxed
DNSMASQ_LISTENING=single
PIHOLE_DNS_1=8.8.8.8
PIHOLE_DNS_2=8.8.4.4
DNS_FQDN_REQUIRED=true
DNS_BOGUS_PRIV=true
DNSSEC=false
CONDITIONAL_FORWARDING=false
[✓] Block page X-Header: X-Pi-hole: A black hole for Internet advertisements.
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
-rw-r--r-- 1 root root 3046249 Sep 9 03:44 /etc/pihole/gravity.list
0.0.0.0
0.r.msn.com
0.start.bz
000.0x1f4b0.com
zzz.clickbank.net
zzzezeroe.fr
zzzpooeaz-france.com
zzzrtrcm2.com
-rw-r--r-- 1 root root 381 Aug 25 15:41 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 91 Sep 6 12:39 /etc/pihole/blacklist.txt
spectrum.s3.amazonaws.com
kindle-time.amazon.com
dns.msftncsi.com
ro20.ru
graph.oculus.com
-rw-r--r-- 1 root root 43 Sep 9 03:44 /etc/pihole/local.list
192.168.1.201 pizza1
192.168.1.201 pi.hole
-rw-r--r-- 1 root root 238 Aug 25 15:42 /etc/pihole/logrotate
/var/log/pihole.log {
su root syslog
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root syslog
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-r--r-- 1 root root 0 Sep 6 12:36 /etc/pihole/whitelist.txt
-rw-r--r-- 1 root root 1533 Sep 11 21:16 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries=extra
local-ttl=2
log-async
server=8.8.8.8
server=8.8.4.4
domain-needed
bogus-priv
interface=eno1
-rw-r--r-- 1 root root 3027 Aug 25 15:42 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ ".ttf$" {
url.access-deny = ("")
-rw-r--r-- 1 root root 1496 Aug 25 15:42 /etc/cron.d/pihole
44 3 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity
00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local
57 12 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 4199 Sep 12 23:19 /var/log/lighttpd/error.log
2018-09-10 06:25:02: (server.c.1534) logfiles cycled UID = 0 PID = 8757
2018-09-10 10:59:15: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: dns_get_record(): A temporary server error occurred. in /var/www/html/pihole/index.php on line 193
2018-09-10 10:59:15: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: array_key_exists() expects parameter 2 to be array, null given in /var/www/html/pihole/index.php on line 194
2018-09-10 11:18:25: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: unlink(../custom_disable_timer): No such file or directory in /var/www/html/admin/api.php on line 47
2018-09-10 11:19:01: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: unlink(../custom_disable_timer): No such file or directory in /var/www/html/admin/api.php on line 72
2018-09-10 11:19:18: (server.c.1828) server stopped by UID = 0 PID = 1
2018-09-10 12:11:54: (log.c.217) server started
2018-09-11 00:12:13: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: dns_get_record(): A temporary server error occurred. in /var/www/html/pihole/index.php on line 193
2018-09-11 00:12:13: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: array_key_exists() expects parameter 2 to be array, null given in /var/www/html/pihole/index.php on line 194
2018-09-11 05:20:57: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: dns_get_record(): A temporary server error occurred. in /var/www/html/pihole/index.php on line 193
2018-09-11 05:20:57: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: array_key_exists() expects parameter 2 to be array, null given in /var/www/html/pihole/index.php on line 194
2018-09-11 15:22:04: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: dns_get_record(): A temporary server error occurred. in /var/www/html/pihole/index.php on line 193
2018-09-11 15:22:04: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: array_key_exists() expects parameter 2 to be array, null given in /var/www/html/pihole/index.php on line 194
2018-09-11 20:44:38: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: unlink(../custom_disable_timer): No such file or directory in /var/www/html/admin/api.php on line 47
2018-09-11 20:46:57: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: unlink(../custom_disable_timer): No such file or directory in /var/www/html/admin/api.php on line 47
2018-09-11 20:55:56: (server.c.1828) server stopped by UID = 0 PID = 1
2018-09-11 20:56:28: (log.c.217) server started
2018-09-11 21:09:38: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: unlink(../custom_disable_timer): No such file or directory in /var/www/html/admin/api.php on line 47
2018-09-11 21:10:36: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: unlink(../custom_disable_timer): No such file or directory in /var/www/html/admin/api.php on line 47
2018-09-11 21:12:48: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: unlink(../custom_disable_timer): No such file or directory in /var/www/html/admin/api.php on line 47
2018-09-11 21:16:37: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: unlink(../custom_disable_timer): No such file or directory in /var/www/html/admin/api.php on line 47
2018-09-11 23:24:31: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10
2018-09-12 08:24:43: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: dns_get_record(): A temporary server error occurred. in /var/www/html/pihole/index.php on line 193
-rw-r--r-- 1 pihole pihole 3940 Sep 12 23:19 /var/log/pihole-FTL.log
[2018-09-12 22:47:49.793] ########## FTL started! ##########
[2018-09-12 22:47:49.793] FTL branch:
[2018-09-12 22:47:49.793] FTL version: v4.0
[2018-09-12 22:47:49.793] FTL commit: 8493df4
[2018-09-12 22:47:49.793] FTL date: 2018-08-05 13:40:30 -0700
[2018-09-12 22:47:49.793] FTL user: pihole
[2018-09-12 22:47:49.794] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2018-09-12 22:47:49.794] SOCKET_LISTENING: only local
[2018-09-12 22:47:49.794] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2018-09-12 22:47:49.794] MAXDBDAYS: max age for stored queries is 365 days
[2018-09-12 22:47:49.794] RESOLVE_IPV6: Resolve IPv6 addresses
[2018-09-12 22:47:49.794] RESOLVE_IPV4: Resolve IPv4 addresses
[2018-09-12 22:47:49.794] DBINTERVAL: saving to DB file every minute
[2018-09-12 22:47:49.794] DBFILE: Using /etc/pihole/pihole-FTL.db
[2018-09-12 22:47:49.794] MAXLOGAGE: Importing up to 24.0 hours of log data
[2018-09-12 22:47:49.794] PRIVACYLEVEL: Set to 0
[2018-09-12 22:47:49.794] IGNORE_LOCALHOST: Show queries from localhost
[2018-09-12 22:47:49.794] BLOCKINGMODE: Null IPs for blocked domains
[2018-09-12 22:47:49.794] REGEX_DEBUGMODE: Inactive
[2018-09-12 22:47:49.794] Finished config file parsing
[2018-09-12 22:47:49.794] Compiled 0 Regex filters and 0 whitelisted domains in 0.0 msec (0 errors)
[2018-09-12 22:47:49.869] Database successfully initialized
[2018-09-12 22:47:49.870] Imported 0 queries from the long-term database
[2018-09-12 22:47:49.870] -> Total DNS queries: 0
[2018-09-12 22:47:49.870] -> Cached DNS queries: 0
[2018-09-12 22:47:49.870] -> Forwarded DNS queries: 0
[2018-09-12 22:47:49.870] -> Exactly blocked DNS queries: 0
[2018-09-12 22:47:49.870] -> Unknown DNS queries: 0
[2018-09-12 22:47:49.870] -> Unique domains: 0
[2018-09-12 22:47:49.870] -> Unique clients: 0
[2018-09-12 22:47:49.870] -> Known forward destinations: 0
[2018-09-12 22:47:49.870] Successfully accessed setupVars.conf
[2018-09-12 23:19:09.977] ########## FTL started! ##########
[2018-09-12 23:19:09.978] FTL branch:
[2018-09-12 23:19:09.978] FTL version: v4.0
[2018-09-12 23:19:09.978] FTL commit: 8493df4
[2018-09-12 23:19:09.978] FTL date: 2018-08-05 13:40:30 -0700
[2018-09-12 23:19:09.978] FTL user: pihole
[2018-09-12 23:19:09.978] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2018-09-12 23:19:09.978] SOCKET_LISTENING: only local
[2018-09-12 23:19:09.978] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2018-09-12 23:19:09.978] MAXDBDAYS: max age for stored queries is 365 days
[2018-09-12 23:19:09.978] RESOLVE_IPV6: Resolve IPv6 addresses
[2018-09-12 23:19:09.978] RESOLVE_IPV4: Resolve IPv4 addresses
[2018-09-12 23:19:09.978] DBINTERVAL: saving to DB file every minute
[2018-09-12 23:19:09.978] DBFILE: Using /etc/pihole/pihole-FTL.db
[2018-09-12 23:19:09.978] MAXLOGAGE: Importing up to 24.0 hours of log data
[2018-09-12 23:19:09.978] PRIVACYLEVEL: Set to 0
[2018-09-12 23:19:09.978] IGNORE_LOCALHOST: Show queries from localhost
[2018-09-12 23:19:09.978] BLOCKINGMODE: Null IPs for blocked domains
[2018-09-12 23:19:09.978] REGEX_DEBUGMODE: Inactive
[2018-09-12 23:19:09.978] Finished config file parsing
[2018-09-12 23:19:09.978] Compiled 0 Regex filters and 0 whitelisted domains in 0.0 msec (0 errors)
[2018-09-12 23:19:09.978] Database successfully initialized
[2018-09-12 23:19:09.979] Imported 0 queries from the long-term database
[2018-09-12 23:19:09.979] -> Total DNS queries: 0
[2018-09-12 23:19:09.979] -> Cached DNS queries: 0
[2018-09-12 23:19:09.979] -> Forwarded DNS queries: 0
[2018-09-12 23:19:09.979] -> Exactly blocked DNS queries: 0
[2018-09-12 23:19:09.979] -> Unknown DNS queries: 0
[2018-09-12 23:19:09.979] -> Unique domains: 0
[2018-09-12 23:19:09.979] -> Unique clients: 0
[2018-09-12 23:19:09.979] -> Known forward destinations: 0
[2018-09-12 23:19:09.979] Successfully accessed setupVars.conf
*** [ DIAGNOSING ]: Locale
LANG=en_US.UTF-8
-rw-r--r-- 1 pihole pihole 0 Sep 12 23:19 /var/log/pihole.log
-----head of pihole.log------
