Good day all
The issue I am facing:
Details about my system:
Samsung galaxy android version 13.
(Phone is rooted)
Note: I followed those steps on this site:
https://github.com/DesktopECHO/Pi-hole-for-Android
And it doesn't wanna work.
Thanks
Good day all
(Phone is rooted)
Thanks
You would need to raise any issues with the maintainer of that project.
Note that once Pi-hole is in use it forms an important part of your network. Therefore it is probably best to have it running on a supported system and in use by mobile devices, rather than trying to run it directly on a mobile OS. That said, if it's just trying it out for fun then go for it, but it's not an official build.
Oh I see!
Yes im very noob when it comes to this kind of stuff.
Is there an official guide on how to install on PC?
Thanks in advance.
If the PC is running a supported OS, yes, see the main site.
