gsp
March 18, 2018, 4:10am
1
My Pi-hole installation didn't go well. There was no error but as part of restarting services as soon as starting dnsmasq, the installation process got terminated. On restarting again I was able to access the website but it shows FTL Offline, I tried few things I saw as answers for other topics commenting out the log line from /etc/dnsmasq.d/01-pihole.conf but didn't solve it.
Please help
My Debug Token sp13raiv7u
gsp
March 18, 2018, 8:39am
2
My Debug token - sp13raiv7u
v3.3 of Pi-hole isn't supported on Jessie. You have two options:
Update: 2018-08-06
As of v4.0, Pi-hole ships with _FTL_DNS, our fork of dnsmasq, which should restore compatibility with Raspbian Jessie. We still recommend installing a newer OS as Jessie is EOL anyway.
Please note that this tutorial is only meant for Rasbian Jessie, although it might (to some extend) also help with similar issues on other Debian versions. Do this at your own risk (however, the likeliness of a failure is rather small in our opinion).
First step: Download more recent versio…
if you want to run a different version of Pi-hole, it is possible to install an older version. Typically, we release all three components of Pi-hole at the same time (Core, Web, and FTL), so you'll usually want to install version from the same "release."
For example, we ran into some issues with v3.3 and dnsmasq compatibility with some systems, so some users needed to revert to v3.2.1 (Core and Web) but as part of the 3.2.1 "release," the latest version of FTL was 2.13.2.
Because we version e…
Please also see this for more information:
Update: 2018-08-06
By default, Raspbian Jessie only supports dnsmasq v2.72, which does not work with the log-queries=extra flag, which is required for Pi-hole v3.3+. You may see error messages such as:
dnsmasq: extraneous parameter at line 37 of /etc/dnsmasq.d/01-pihole.conf
failed!
There are two options…
gsp
March 18, 2018, 4:37pm
4
Thanks a lot!!!. I updated to dnsmasq 2.76 and it worked!
system
Closed
June 16, 2018, 11:40pm
5
