Installation problem
[i] Using privacy level: 0
[✓] Check for existing repository in /etc/.pihole
[i] Update repo in /etc/.pihole...
: Could not update local repository. Contact support.
-operating system
-hardware]
I everybody, i have a corporate FW so when i try to install the soft the fw reject me.
my question is, can anybody can provide the url /s to pi-hole use to connect, so i will make a request to the sistem area in my company]
You can check all needed URLs searching the source code:
I think you will need to allow Github and a few other domains.
During the installation you will need access to:
  • https://install.pi-hole.net (of course...)
  • many different URLs starting with https://github.com/pi-hole
  • 2 URLs from https://raw.githubusercontent.com and
  • the installer downloads pihole-FTL from https://ftl.pi-hole.net (the full URL depends on the machine architecture).
i and thanks, for the anwser.
i was get all the urls, and i have permision but steal have the same error
[root@plhbednsaapp001 automated install]# curl -V
curl 7.61.1 (x86_64-redhat-linux-gnu) libcurl/7.61.1 OpenSSL/1.1.1k zlib/1.2.11 brotli/1.0.6 libidn2/2.2.0 libpsl/0.20.2 (+libidn2/2.2.0) libssh/0.9.6/openssl/zlib nghttp2/1.33.0
Release-Date: 2018-09-05
Protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps pop3 pop3s rtsp scp sftp smb smbs smtp smtps telnet tftp
Features: AsynchDNS IDN IPv6 Largefile GSS-API Kerberos SPNEGO NTLM NTLM_WB SSL libz brotli TLS-SRP HTTP2 UnixSockets HTTPS-proxy PSL
[root@plhbednsaapp001 ~]# curl -sSL https://install.pi-hole.net | sudo PIHOLE_SKIP_OS_CHECK=true bash
[✓] Root user check
    .ccccc:,.
     :cccclll:.      ..,,
      :ccccclll.   ;ooodc
       'ccll:;ll .oooodc
         .;cll.;;looo:.
[✓] Default SELinux: disabled
[✓] Current SELinux: disabled
[✓] EPEL repository already installed
[✓] Checking dnf for upgraded packages... 11 updates available
[i] It is recommended to update your OS after installing the Pi-hole!
[i] Checking for / installing Required dependencies for OS Check...
[✓] Checking for grep
[✓] Checking for bind-utils
[i] PIHOLE_SKIP_OS_CHECK env variable set to true - installer will continue
[i] Checking for / installing Required dependencies for this install script...
[✓] Checking for git
[✓] Checking for dialog
[✓] Checking for iproute
[✓] Checking for newt
[✓] Checking for procps-ng
[✓] Checking for chkconfig
[✓] Checking for ca-certificates
Initiating network interface
                                             +-------------------------Static IP Needed---------------------------+
                                             | The Pi-hole is a SERVER so it needs a STATIC IP ADDRESS to         |
                                             | function properly.                                                 |
                                             | IMPORTANT: If you have not already done so, you must ensure that   |
                                             | this device has a static IP.                                       |
                                             | Depending on your operating system, there are many ways to achieve |
                                             | this, through DHCP reservation, or by manually assigning one.      |
                                             | Please continue when the static addressing has been configured.    |
                                             |                   <Continue>          <  Exit  >                   |
[i] IPv4 address: 10.173.34.204/24
[i] Unable to find IPv6 ULA/GUA address
[i] IPv6 address:
                                             | |                Google (ECS, DNSSEC)                            | |
                                             | |                OpenDNS (ECS, DNSSEC)                           | |
                                             | |                Level3                                          | |
                                             | Select Upstream DNS Provider. To use your own, select Custom.      |
                                             | |                Comodo                                          | |
                                             | |                DNS.WATCH (DNSSEC)                              | |
                                             | |                Quad9 (filtered, DNSSEC)                        | |
                                             | |                Quad9 (unfiltered, no DNSSEC)                   | |
                                             | |                Quad9 (filtered, ECS, DNSSEC)                   | |
                                             | |                Cloudflare (DNSSEC)                             | |
                                             | |                Custom                                          | |
                                             | +--------+)----------------------------------------------100%%-----+ |
                                             |                   <  OK  >          < Exit >                       |
Specify Upstream DNS Provider(s)
                                             | Enter your desired upstream DNS provider(s), separated by a        |
                                             | comma.If you want to specify a port other than 53, separate it     |
                                             | with a hash.                                                       |
                                             | For example '8.8.8.8, 8.8.4.4' or '127.0.0.1#5335'                 |
                                             | |10.173.35.233                                                   | |
                                             |                   <  OK  >          < Exit >                       |
                                             +---------------------Upstream DNS Provider(s)-----------------------+
                                             | Are these settings correct?                                        |
                                             |       DNS Server 1:   10.173.35.233                                |
                                             |       DNS Server 2:   10.173.35.233                                |
                                             |                     < Yes >           < No  >                      |
[i] Using upstream DNS: Custom (10.173.35.233, 10.173.35.233)
Pi-hole Installation
                                             +----------------------------Blocklists------------------------------+
                                             | Pi-hole relies on third party lists in order to block ads.         |
                                             | You can use the suggestion below, and/or add your own after        |
                                             | installation.                                                      |
                                             | Select 'Yes' to include:                                           |
                                             | StevenBlack's Unified Hosts List                                   |
                                             |                     < Yes >           < No  >                      |
[i] Installing StevenBlack's Unified Hosts List
Pihole Installation
                                             +-----------------------Admin Web Interface--------------------------+
                                             | Do you want to install the Admin Web Interface?                    |
                                             |                     < Yes >           < No  >                      |
[i] Installing Admin Web Interface
                                             +----------------------------Web Server------------------------------+
                                             | A web server is required for the Admin Web Interface.              |
                                             | Do you want to install lighttpd and the required PHP modules?      |
                                             | NB: If you disable this, and, do not have an existing web server   |
                                             | and required PHP modules (cli pdo xml json intl) installed, the    |
                                             | web interface will not function. Additionally the web server user  |
                                             | needs to be member of the "pihole" group for full functionality.   |
                                             |                     < Yes >           < No  >                      |
[i] Installing lighttpd
Pihole Installation
                                             +--------------------------Enable Logging----------------------------+
                                             | Would you like to enable query logging?                            |
                                             |                     < Yes >           < No  >                      |
[i] Query Logging on.
                                             | Select a privacy mode for FTL.                                     |
                                             | https://docs.pi-hole.net/ftldns/privacylevels/                     |
                                             | |                (*) 0  Show everything                          | |
                                             | |                ( ) 1  Hide domains                             | |
                                             | |                ( ) 2  Hide domains and clients                 | |
                                             | |                ( ) 3  Anonymous mode                           | |
btw i have a personal computer using ubuntu model and its working, but i need to instal ond redhat
thanks a lot
This is clearly an OS level issue.
Note:
Red Hat is not officially supported and I'm not sure if you will be able to install Pi-hole.
Apparently git or another dependency was not correctly installed.
Please try the commands below and post the result:
cd /etc/.pihole
git status
[root@plhbednsaapp001 .pihole]# git branch -r
origin/HEAD -> origin/master
origin/checkout/tags
origin/dev2
origin/development
origin/fix/migration_test
origin/fix_FTLcheckUpdate
origin/master
origin/remove-restartdns
origin/tweak/gravity_backup
origin/tweak/os-check-on-update
origin/update_tests_fedora_v5
[root@plhbednsaapp001 .pihole]# git status
On branch master
Your branch is up to date with 'origin/master'.
nothing to commit, working tree clean
solution
sudo PIHOLE_SKIP_OS_CHECK=true bash -x /etc/.pihole/automated\ install/basic-install.sh
and install perfect
thanks everybody
