Installation on RPI 5 Debian 12 issue after OS update
I had pihole installed successfully on my pi5. The OS is on a NVMe SSD. After an update && upgrade pihole is running, but not blocking anything anymore. I checked the IP address, it stayed the same and I ran the diagnostics and (beside pihole couldn't resolve two ipv6 addresses) the diagnostics doesn't find the /etc/lighttpd/conf.d. So I think that could be the issue.
Did anyone had the same issue with a Debian12 update and could solve it?
My debug-token is https://tricorder.pi-hole.net/EwtyieO0/
This is expected on Debian.
That directory only exists on Fedora/CentOS.
Your Pi-hole is using 192.168.1.42, but your router is advertising itself as DNS server:
router: 192.168.1.1
dns-server: 192.168.1.1
How did you configure your devices to use Pi-hole?
thank you for the quick reply. Like most Germans I am using the FritzBox. there I can set the default DNS-Server IP and the IP of a backup DNS. It is set to 192.168.1.42, e.g. pihole. I didn't change anything there, I just rechecked it searching for the Error.
I did all settings during the installation procedure and didn't change anything, else except the settings at the FritzBox Router.
Thank you for your analysis, I checked /etc/reslov.conf and there was (out of which reasons) 192.168.1.1, so changed that back to my pihole 192.168.1.42 and it runs now.
I should have checked the diagnostics more carefulyy, proise to improve :wink:
That would indicate that you did configure your FritzBox to use Pi-hole as its upstream resolver.
FritzBox routers also support telling clients to use your Pi-hole machine as local DNS. This would be the preferred configuration, as it would allow Pi-hole to attribute DNS requests to individual clients.
You may want to refer to our Fritz!Box (DE) - Pi-hole documentation for a few recommendations on FritzBox configuration options.
Thanks for that information, that post was quite helpful. I reconfigured the FritzBox to have ppihole as local DNS, still dosn't wan't to block anymore, I will see what is wrong this time.
You shouldnt configure a "backup" DNS:
Thank you for that clarification :wink:
