Installation hangs
Install completes
Installation hangs after this step
[✓] Checking for php7.0-sqlite3
NB: same issue happened when trying to upgrade from 3.3. Removed 3.3 and tried a fresh install, same behaviour occurs.
Cannot get one :slight_smile:
What platform and OS are you using to host Pi-Hole?
Raspberry pi Model B with latest raspbian, all up to date.
pi@raspberrypi:~ $ cat /proc/version
Linux version 4.14.52-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1123 SMP Wed Jun 27 17:35:49 BST 2018
Is there any other command I can run to give you more info? I have tried the obvious things e.g. rebooting etc.
Thanks!
Yes.
pihole -v reports the pihole version
When you run pihole -d , what is the output? You mentioned you cannot get a debug token. If you can generate a debug log, you can paste it here and we'll make it private.
Maybe I haven't been very clear... pihole does not install at all. The installer hangs after that step. So I cannot run it...
Oh. It now seems to be working. Did exactly the same thing as this morning, curl etc etc. Very bizarre! Apologies for the fuss...
I apologize for my confusion. I was thinking update. Glad that it's working properly for you now.
