MacGy
January 12, 2021, 8:14pm
1
Hello Guys, thanks for your help
Pi-hole installation works and blacklist has mulitple entries
Pulling blocklist source list into range fails
Black Lists shows (-2) no entries
Run installation twice to try again, didn't help apparently.
Sorry I am newbie in Linux, raspberry and pi-hole. I didnt finde an up to date topic that sounds similar
Thanks for your time and effort
MacGy
Can you please generate a debug log with pihole -d
and post the token here?
MacGy
January 13, 2021, 5:01pm
3
Hello yubiuser, thanks for your help and sorry for the late reply. I generated the token here:
https://tricorder.pi-hole.net/h1611epq59
hope that helps!
Thanks in advance!
EDIT:
can it be a problem, that i acess the pi by teamviewer, since i dont want to put the screen and mouse on again?
MacGy
Your Pi-hole device is connected via wlan0
, but configured to use eth0
. Run pihole -r
choose repair
and change the interface (normally reconfigure
would be enough to change the interface, but you experience database errors as well).
Additionally, your router advertises itself via DHCP as DNS server to clients, you might want to change that.
MacGy
January 13, 2021, 5:20pm
5
Hey, thanks a lot for your input.
I did both actually, first reconfigure and than repair, the DHCP I changed in the fritzbox, so that should be working now, that it forwards all traffic via Pihole.
But the error messages stay the same: here the new generated token:
https://tricorder.pi-hole.net/ez1sj0q5ze
or as i meant as edit, does the teamviewer messes it up?
Thanks for the support!
MacGy
Looks better now, even if not fully solved
Try to add an adlist via web interface
and re-run gravity
pihole -g
MacGy
January 13, 2021, 8:33pm
7
Mmh that seems also to fail:
And pihole -g looks still messed beginning with the blocklist, gravity tree and gravity tree timestamp:
Check if there is a gravity database at all in /etc/pihole
ls -lha /etc/pihole/
MacGy
January 14, 2021, 7:58am
9
Actually i see i have two, there is a temp version listed as well:
Should I delete the temp one?
Thanks for the in detail support you give!
MacGy
I would delete both, and run pihole -r
again.
yubiuser
Split this topic
January 15, 2021, 4:37am
11
3 posts were split to a new topic: Malwaredomains list doesn't exist
system
Closed
February 5, 2021, 4:37am
12
