Install PiHole in a virtual machine, using Debian 11.3.0-amd64:
- Select the correct installation media version
When installing Debian, it is a relatively smooth version
O > debian-11.3.0-amd64-netinst.iso
If using the DVD version, there may be errors during the installation process
X > debian-11.3.0-amd64-DVD-1.iso
- Desktop Select GNOME
O > At least install the GNOME desktop, and log in for the first time, the traditional network manager will be installed, and you can switch to other desktops after the first login
X > If only the LXQt desktop is installed and the network manager is connman, there will be a port 53 conflict
, the DNS cannot be enabled, the connman service must be disabled, which affects the network setting GUI
