_eMa
1
I try to install pi-hole on my UniFi Cloud Key ( armv7l withDebian GNU/Linux 8.10 )
but i have a error on "starting dnsmasq service " and this stop the installation
link : https://c1.staticflickr.com/5/4711/26611729288_3d3b8987fe_c.jpg
On dashboard :
link: https://c1.staticflickr.com/5/4626/26611740498_238180f9b5_b.jpg
I try to downgrade the firmware of CK, but same error.
Last year, I install pi-hole on other Cloud-Key without error
https://c1.staticflickr.com/5/4332/36746434991_a2ab0b2708_o.png
Help
Mcat12
2
What is the output of these commands?
sudo service dnsmasq status
sudo service dnsmasq start
_eMa
3
Hi!
I follow this fix
https://discourse.pi-hole.net/t/install-a-more-recent-dnsmasq-on-raspbian-jessie/7306
and now I don't have errors...but I have not query to my pi-hole
https://c1.staticflickr.com/5/4770/40500563232_ecc0fa3078_b.jpg
This is the output of your commands :
root@UniFi-CloudKey:~# sudo service dnsmasq status
- dnsmasq.service - dnsmasq - A lightweight DHCP and caching DNS server
Loaded: loaded (/lib/systemd/system/dnsmasq.service; enabled)
Drop-In: /run/systemd/generator/dnsmasq.service.d
-50-dnsmasq-$named.conf, 50-insserv.conf-$named.conf Active: active (running) since Wed 2018-02-28 08:10:20 CET; 14h ago Process: 506 ExecStartPost=/etc/init.d/dnsmasq systemd-start-resolvconf (code=exited, status=0/SUCCESS) Process: 499 ExecStart=/etc/init.d/dnsmasq systemd-exec (code=exited, status=0/SUCCESS) Process: 426 ExecStartPre=/usr/sbin/dnsmasq --test (code=exited, status=0/SUCCESS) Main PID: 505 (dnsmasq) CGroup: /system.slice/dnsmasq.service -505 /usr/sbin/dnsmasq -x /run/dnsmasq/dnsmasq.pid -u dnsmasq -7 ...
root@UniFi-CloudKey:~# sudo service dnsmasq start
-50-dnsmasq-$named.conf, 50-insserv.conf-$named.conf Active: active (running) since Wed 2018-02-28 08:10:20 CET; 14h ago Process: 506 ExecStartPost=/etc/init.d/dnsmasq systemd-start-resolvconf (code=exited, status=0/SUCCESS) Process: 499 ExecStart=/etc/init.d/dnsmasq systemd-exec (code=exited, status=0/SUCCESS) Process: 426 ExecStartPre=/usr/sbin/dnsmasq --test (code=exited, status=0/SUCCESS) Main PID: 505 (dnsmasq) CGroup: /system.slice/dnsmasq.service -505 /usr/sbin/dnsmasq -x /run/dnsmasq/dnsmasq.pid -u dnsmasq -7 /etc/dnsmasq.d,.dpkg-dist,.dpkg-old,.dpkg-new --local-service
Mcat12
4
Run pihole -d for a new debug token. Do you see any queries if you directly use Pi-hole? (replace pi.hole.ip.address)
dig doubleclick.com @pi.hole.ip.address
