Can you still install pi-hole version 5?
Yes, depending on your distro, you can access their package archives and install v5 from there.
If you are running docker, you'll just change the version tag on pihole/pihole:latest to pihole/pihole:2024.07.0
I'm running it in a Proxmox VM.
What is the output of uname -v
#1 SMP PREEMPT_DYNAMIC Debian 6.1.128-1 (2025-02-07)
It seems that debian does not package pihole.
Your best bet would be to download the source code & run the basic-install.sh
[i] Downloading and Installing FTL...curl: (22) The requested URL returned error: 404
Error: URL https://github.com/pi-hole/ftl/releases/latest/download/pihole-FTL-linux-x86_64 not found
[✗] FTL Engine not installed
root@blackhole2:~/pi-hole-5.18.4#
Looks like they dont want us to roll back to 5.
In theory it still may be possible, you'd just have to edit the script to point to the correct releases for webInterfaceGitUrl, pihole-FTL (line 2231 in script), and piholeGitUrl
Use a docker install and pull the V5 container.
No. That's not the case.
The issue is a combination of things:
- Pi-hole installer always initially installs the current version (this is v6). After that you can change to a different tag, but the installed version needs to be compatible;
- v6 installer is different than v5 installer;
- v6 uses different naming for FTL files. As a result, the v6 installer can't find the correct v5 FTL (just like you noticed above);
- many users complete the migration to v6. A few users were not able to completely install v6 and each of these cases failed in a different step, so there are too many different cases to find a single solution;
- making a new installer to allow installing old versions is out of the question (it will demand time we don't have for testing).;
- we are using all our free time to answer questions here and fix/improve v6, so there is no available time to go 10, 20 or more steps to teach each individual user how to go back to a previous version.
Using docker image 2024.07.0
is a very simple way to use Pi-hole v5.
