Install fails at FTL - appears to be a certificate problem
Installation completing as normal
Install always fails at installing FTL step with an error message. Reproducible every time.
cn0f90tr29
Fresh install of Raspbian Stretch Lite on a Pi Zero or an old Pi 1, both with the same results.
Installation works as expected with the exception of FTL:
[i] FTL Checks...
[‚úì] Detected ARM-hf architecture (armv6 or lower) Using ARM binary
[i] Downloading and Installing FTL...curl: (60) SSL certificate problem: self signed certificate in certificate chain
More details here: https://curl.haxx.se/docs/sslcerts.html
curl performs SSL certificate verification by default, using a "bundle"
of Certificate Authority (CA) public keys (CA certs). If the default
bundle file isn't adequate, you can specify an alternate file
using the --cacert option.
If this HTTPS server uses a certificate signed by a CA represented in
the bundle, the certificate verification probably failed due to a
problem with the certificate (it might be expired, or the name might
not match the domain name in the URL).
If you'd like to turn off curl's verification of the certificate, use
the -k (or --insecure) option.
[‚úó] Downloading and Installing FTL
Error: URL not found
[‚úó] FTL Engine not installed
I've ensured there is a valid entry for DNS server in /etc/resolv.conf. No option to use the -k option for curl as the url is called by the install script.
Any help much appreciated!
Barry.
Check the time and date on the Pi. If the time is off, then the certificate won't work.
date
Related threads:
Thanks for the quick reply jfb.
Date & time are correct:
pi@raspberrypi:~$ date
Wed 31 Oct 02:02:08 GMT 2018
certs seem to be in place:
pi@raspberrypi:~$ ls /etc/ssl/certs | wc -l
454
pi@raspberrypi:~$  ls /etc/ssl/certs | grep COMODO
COMODO_Certification_Authority.pem
COMODO_ECC_Certification_Authority.pem
COMODO_RSA_Certification_Authority.pem
Checking install now with curl -sSLk, i'll report back asap!
Same issue with curl -sSLk unfortunately:
 [i] FTL Checks...
Just a little more info - sudo apt-get update & apt-get upgrade was carried out prior to pi-hole installation.
All sorted now!
It was my own fault - my firewall was blocking the FTL installation :roll_eyes:
