Initial deployment docker errors
Hello, I am attempting my first deployment of Pi hole. looks like a great product.
I am using docker, every time I deploy, the container starts. but UI never comes up. I restart the container, UI works but I get the following error, and things are not working correctly.
Not sure what I am doing wrong, hopefully someone can help
Info:
using pihole:latest
tried running pihole -g
tried deleting the DB's and restarting.
 ::: Docker start setup complete
Error: no such table: info
  [✗] Pulling blocklist source list into range
  [i] No source list found, or it is empty
  [i] Building tree...
  [✗] Unable to build gravity tree in /etc/pihole/gravity_temp.db
  Error: no such table: main.gravity
  [✗] Unable to update gravity timestamp in database /etc/pihole/gravity.db
  Error: near line 2: no such table: info
Error: no such table: vw_gravity
  [i] Number of gravity domains:  ( unique domains)
Error: near ")": syntax error
Error: no such table: vw_blacklist
  [i] Number of exact blacklisted domains:
Error: no such table: vw_regex_blacklist
  [i] Number of regex blacklist filters:
Error: no such table: vw_whitelist
  [i] Number of exact whitelisted domains:
Error: no such table: vw_regex_whitelist
  [i] Number of regex whitelist filters:
  [✓] Cleaning up stray matter
Your likely facing this issue because ot
You can try to fix this by creating the file
/etc/pihole/adlists.list
and add at least one adlist like https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
then run
pihole -g -r
No go.
root@pi:/# cat /etc/pihole/adlist.list
root@pi:/# pihole -g -r
  [✓] Restoring from migration backup
  [i] Creating new gravity database
  [i] Migrating content of /etc/pihole/adlists.list into new database
  [i] Number of gravity domains: 0 (0 unique domains)
  [i] Number of exact blacklisted domains: 0
  [i] Number of regex blacklist filters: 0
  [i] Number of exact whitelisted domains: 0
  [i] Number of regex whitelist filters: 0
  [✓] Flushing DNS cache
  [✓] DNS service is running
You missed a s, it's adlists.list
I think the appropriate location for the adlists.list is in the migration_backup folder. That is where the gravity recreate code obtains the lists.
Good thought, but I think it doesn't matter as the content of migration_backup is just copied to ${piholeDir} (/etc/pihole in most cases)
That's the point. If changes are made to a file in /etc/pihole, they are overwritten by the information from the migration_backup, which includes all the information at the time of conversion . So, make the changes in the migration_backup folder.
As this is a docker related issue and pihole's container is not supposed to be updated (and the OP didn't mention v4 - > v5 update) the migration backup folder should be empty. Therfore is should not matter where the file is changed (or in this case created at all).
Indeed a typo... OOPS.
indeed also not a migration. new setup on docker.
root@pi:/# cat /etc/pihole/adlists.list
[i] Restoring from migration backup...rm: cannot remove '/etc/pihole/gravity.db': No such file or directory
Ok, try to copy adlists.list to /etc/pihole/migration_backup and see if this helps (I personally doubt, but would be happy if convinced otherwise).
Also check file system permissions of /etc/pihole/
nanopi@nanopi:~$ ls -lha /etc/pihole/
total 346M
drwxrwxr-x  2 pihole pihole 4,0K Jun 25 09:18 .
drwxr-xr-x 94 root   root   4,0K Jun 25 08:08 ..
-rw-r--r--  1 root   root    276 Mai 12 20:02 adlists.list
-rw-r--r--  1 root   root    490 Jun 10 20:26 custom.list
-rw-r--r--  1 pihole pihole    0 Jun 25 09:12 dhcp.leases
-rw-r--r--  1 root   root    596 Jun 25 08:08 dns-servers.conf
-rw-r--r--  1 root   root     16 Jun 24 09:46 ftlbranch
-rw-r--r--  1 root   root     14 Jun 25 08:09 GitHubVersions
-rw-rw-r--  1 pihole pihole  96M Jun 25 08:09 gravity.db
-rw-r--r--  1 root   root   4,3M Jan 19 04:30 gravity.list
-rw-r--r--  1 root   root   1,1K Jun 25 08:08 install.log
-rw-r--r--  1 root   root   537K Jun 25 08:08 list.0.raw.githubusercontent.com.domains
-rw-r--r--  1 root   root   413K Jun 25 08:08 list.10.raw.githubusercontent.com.domains
-rw-r--r--  1 root   root   4,2M Jun 25 08:08 list.11.raw.githubusercontent.com.domains
-rw-r--r--  1 root   root   1,2M Jun 25 08:08 list.12.raw.githubusercontent.com.domains
-rw-r--r--  1 root   root    15M Jun 25 08:08 list.13.raw.githubusercontent.com.domains
-rw-r--r--  1 root   root   4,0M Jun 25 08:08 list.14.raw.githubusercontent.com.domains
-rw-r--r--  1 root   root    50K Jun 25 08:08 list.15.raw.githubusercontent.com.domains
-rw-r--r--  1 root   root   3,9K Jun 25 08:08 list.16.raw.githubusercontent.com.domains
-rw-r--r--  1 root   root   2,3K Jun 25 08:08 list.1.raw.githubusercontent.com.domains
-rw-r--r--  1 root   root   283K Jun 25 08:08 list.2.raw.githubusercontent.com.domains
-rw-r--r--  1 root   root    22K Jun 25 08:08 list.3.raw.githubusercontent.com.domains
-rw-r--r--  1 root   root    21K Jun 25 08:08 list.4.raw.githubusercontent.com.domains
-rw-r--r--  1 root   root   3,8M Jun 25 08:08 list.5.www.github.developerdan.com.domains
-rw-r--r--  1 root   root   1,1M Jun 25 08:08 list.6.raw.githubusercontent.com.domains
-rw-r--r--  1 root   root      0 Jun 25 08:08 list.7.dehakkelaar.nl.domains
-rw-r--r--  1 root   root   3,3M Jun 25 08:08 list.8.raw.githubusercontent.com.domains
-rw-r--r--  1 root   root    21K Jun 25 08:08 list.9.raw.githubusercontent.com.domains
-rw-r--r--  1 root   root     43 Jun 25 09:10 localbranches
-rw-r--r--  1 root   root     33 Jun 25 08:09 local.list
-rw-r--r--  1 root   root     49 Jun 25 09:10 localversions
-rw-r--r--  1 root   root    234 Jun 25 08:08 logrotate
-rw-r--r--  1 pihole pihole 2,4M Jun 25 08:08 macvendor.db
-rw-rw-r--  1 pihole root    188 Jun 25 09:12 pihole-FTL.conf
-rw-r--r--  1 pihole pihole  17M Jun 25 09:18 pihole-FTL.db
-rw-r--r--  1 pihole pihole 194M Jun  3 22:01 pihole-FTL-new_mac.db
-rw-r--r--  1 root   root    666 Jun 25 08:08 setupVars.conf
-rw-r--r--  1 root   root    666 Jun 25 08:08 setupVars.conf.update.bak
I decided to rebuild volumes and container. First boot, couldnt load the UI. Then i tried the above
First Boot:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] 01-resolver-resolv: applying...
[fix-attrs.d] 01-resolver-resolv: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 20-start.sh: executing...
 ::: Starting docker specific checks & setup for docker pihole/pihole
OK: Checks passed for /etc/resolv.conf DNS servers
nameserver 127.0.0.1
nameserver 1.1.1.1
options timeout:15
options attempts:5
Assigning random password: HAR8cLA6
  [i] Existing PHP installation detected : PHP version 7.0.33-0+deb9u7
  [✓] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
chown: cannot access '': No such file or directory
chmod: cannot access '': No such file or directory
chown: cannot access '/etc/pihole/dhcp.leases': No such file or directory
Setting password: HAR8cLA6
+ pihole -a -p HAR8cLA6 HAR8cLA6
  [✓] New password set
Using default DNS servers: 8.8.8.8 & 8.8.4.4
DNSMasq binding to default interface: eth0
Added ENV to php:
                        "PHP_ERROR_LOG" => "/var/log/lighttpd/error.log",
                        "ServerIP" => "127.0.0.1",
                        "VIRTUAL_HOST" => "pi.hole",
Using IPv4 and IPv6
::: setup_blocklists now setting default blocklists up:
::: TIP: Use a docker volume for /etc/pihole/adlists.list if you want to customize for first boot
::: Blocklists (/etc/pihole/adlists.list) now set to:
::: Testing pihole-FTL DNS: FTL started!
::: Testing lighttpd config: Syntax OK
::: All config checks passed, cleared for startup ...
  [i] Received 57322 domains
  [i] Target: https://mirror1.malwaredomains.com/files/justdomains
  [i] Received 26853 domains
  [i] Target: https://s3.amazonaws.com/lists.disconnect.me/simple_tracking.txt
try with suggested:
root@pi:/# ls -lha /etc/pihole/
total 92K
drwxrwxr-x  3 pihole pihole 4.0K Jun 25 07:55 .
drwxrwxr-x 53 root   root   4.0K Jun 25 07:53 ..
-rw-r--r--  1 root   root     14 Jun 25 07:54 GitHubVersions
-rw-r--r--  1 root   root     65 Jun 25 07:54 adlists.list
-rw-r--r--  1 root   root    596 Jun 25 07:53 dns-servers.conf
-rw-rw-r--  1 pihole pihole    0 May 10 13:50 gravity.db
-rw-r--r--  1 root   root      0 Jun 25 07:53 gravity_temp.db
-rw-r--r--  1 root   root      0 May 10 13:50 install.log
-rw-r--r--  1 root   root      0 May 10 13:50 list.0.raw.githubusercontent.com.domains
-rw-r--r--  1 root   root      0 May 10 13:50 list.1.mirror1.malwaredomains.com.domains
-rw-r--r--  1 root   root      0 May 10 13:50 list.2.s3.amazonaws.com.domains
-rw-r--r--  1 root   root      0 May 10 13:50 list.3.s3.amazonaws.com.domains
-rw-r--r--  1 root   root     36 Jun 25 07:53 local.list
-rw-r--r--  1 root   root     20 Jun 25 07:53 localbranches
-rw-r--r--  1 root   root     37 Jun 25 07:53 localversions
-rw-r--r--  1 root   root      0 May 10 13:50 logrotate
-rw-r--r--  1 pihole pihole    0 May 10 13:50 macvendor.db
drwxr-xr-x  2 root   root   4.0K May 10 13:50 migration_backup
-rw-r--r--  1 pihole pihole    0 May 10 13:50 pihole-FTL.conf
-rw-r--r--  1 root   root    44K Jun 25 07:55 pihole-FTL.db
-rw-r--r--  1 root   root    449 Jun 25 07:53 setupVars.conf
-rw-r--r--  1 root   root    427 Jun 25 07:53 setupVars.conf.update.bak
  [i] Neutrino emissions detected...        [✓] Pulling blocklist source list into range
  [✓] Storing downloaded domains in new gravity database
  [✓] Building tree
  [✓] Swapping databases
  [i] Number of gravity domains: 57322 (57322 unique domains)
So it worked. why does the docker build not work out of the box? do i have a miss config? is this a bug?
It looks like the output is truncated?
Negative. thats where it just stops and sits for hours. until i kill it and restart.
it appears that the below no longer exists? possibly no timeout for the default target lists? so the install never finishes?
Target: https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt
i added the 4 default to my instance again, this is where it is stuck.
  [i] Received 34 domains
  [i] Target: https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt
  [i] Status: Pending...
After adding back the 4. it no longer will start. its stuck trying to update that one list.
I can open it without problems.
Also pihole -g workes
nanopi@nanopi:~$ pihole -g
  [✓] Status: No changes detected
  [i] Received 2701 domains
But both lists are deprecated (outdated) and won't be included from pihole v5.1.
https://github.com/pi-hole/pi-hole/pull/3451
https://github.com/pi-hole/pi-hole/issues/3450
I am able to open it with my web browser. very odd.
at least i have a solution!
what is the best place to get a list of all of the "default" "current" "active" "suggested" lists?
Great!
