Increase TTL
Hi!
After reading Stop using ridiculously low DNS TTLs - Frank DENIS random thoughts. I want to increase the TTL to a good 20 to 40 Minutes.
Are there any downsides other than
I can absolutely live with that, especially now that I know about the issue (If in doubt I may flushdns cache on the client).
Related topic: Change the TTL?
Greets, Blockit
Which TTL? The TTL that comes from the upstream DNS server for any returned DNS request? Or, the TTL that Pi-Hole provides with any domain it blocks?
Note that you won't save much time in DNS lookups with a long TTL. If you dig a random domain from Google or Cloudflare, the lookup time is typically a few tens of msecs and the returned TTL is reasonably long.
Examples:
dig pi-hole.net @1.1.1.1
pi-hole.net. 1742 IN A 206.189.252.21
;; Query time: 18 msec
;; SERVER: 1.1.1.1#53(1.1.1.1)
dig pi-hole.net @8.8.8.8
pi-hole.net. 760 IN A 206.189.252.21
;; Query time: 30 msec
;; SERVER: 8.8.8.8#53(8.8.8.8)
In the dnsmasq manual page, this note appears with the min TTL command:
"--min-cache-ttl=time
Extend short TTL values to the time given when caching them. Note that artificially extending TTL values is in general a bad idea, do not do it unless you have a good reason, and understand what you are doing. Dnsmasq limits the value of this option to one hour, unless recompiled."
In Unbound (unbound.conf) you set it with
server:
  cache-min-ttl: 600
After reading that link I'm more inclined to say the author is not accurate or correct.
We only set the local-ttl, if you want to set up a min-cache-ttl then that's your choice, noting that unless you recompile the binary you will have a minimum time of 1 hour no matter what you set for the value.
Thank you for your answers.
The upstream one.
Yes but I have a few reasons:
  • the DNS server I use is not the fastest (but privacy friendly and uncensored)
  • I want to reduce the number of requests to spare their free DNS service
  • less requests looks like a good idea in general to me
  • minor response time improvement
Well I want to try it and see if it works. Like adding unknown stuff to the blacklist.
@mibere Ok nice and easy!
So no problem if I set it to 40 minutes. Or am I lost in translation here and it will be fixed to 60 minutes ("no matter what I set the value")?
It was lost in translation. 1 hr is the maximum of the minimum ttl.
You should be able to do this.
Thank you all for help, works well now.
I simply put
# Change DNS cache TTL to 40 minutes
min-cache-ttl=2400
into
/etc/dnsmasq.d/05-customadditions.conf
made a restart and according to dig pi-hole.net it works (shows remaining TTL above 3000).
