I uninstalled and reinstalled PiHole as a last ditch effort to get it working again.
For the sake of laziness I thought I would keep the existing saved password.
So: How to change the password on PiHole?
How to change password
pihole -h
Usage: pihole [options]
Example: 'pihole allow -h'
Add '-h' after specific commands for more information on usage
Domain Options:
allow, allowlist Allow domain(s)
deny, denylist Deny domain(s)
--regex, regex Regex deny domains(s)
--allow-regex Regex allow domains(s)
--wild, wildcard Wildcard deny domain(s)
--allow-wild Wildcard allow domain(s)
Add '-h' for more info on allow/deny usage
Debugging Options:
-d, debug Start a debugging session
Add '-c' or '--check-database' to include a Pi-hole database integrity check
Add '-a' to automatically upload the log to tricorder.pi-hole.net
-f, flush Flush the Pi-hole log
-r, repair Repair Pi-hole subsystems
-t, tail [arg] View the live output of the Pi-hole log.
Add an optional argument to filter the log
(regular expressions are supported)
api <endpoint> Query the Pi-hole API at <endpoint>
Precede <endpoint> with 'verbose' option to show authentication and status messages
Options:
setpassword [pwd] Set the password for the web interface
Without optional argument, password is read interactively.
When specifying a password directly, enclose it in single quotes.
-g, updateGravity Update the list of ad-serving domains
-h, --help, help Show this help dialog
-l, logging Specify whether the Pi-hole log should be used
Add '-h' for more info on logging usage
-q, query Query the adlists for a specified domain
Add '-h' for more info on query usage
-up, updatePihole Update Pi-hole subsystems
Add '--check-only' to exit script before update is performed.
-v, version Show installed versions of Pi-hole, Web Interface & FTL
uninstall Uninstall Pi-hole from your system
status Display the running status of Pi-hole subsystems
enable Enable Pi-hole subsystems
Add '-h' for more info on enable usage
disable Disable Pi-hole subsystems
Add '-h' for more info on disable usage
reloaddns Update the lists and flush the cache without restarting the DNS server
reloadlists Update the lists WITHOUT flushing the cache or restarting the DNS server
checkout Switch Pi-hole subsystems to a different GitHub branch
Add '-h' for more info on checkout usage
arpflush Flush information stored in Pi-hole's network tables
There is no -a option.
