I have been running for about 2 years docker-compose with Pi-hole and just did a pull and updated. After the update I am getting errors where the container can't get the current date and is returning errors:
pihole | [1969-12-31 19:00:51.-1225030 497M] DB warn: TIMESTAMP should be larger than 01/01/2017 but is 6
pihole | [1969-12-31 19:00:51.-sudo: unable to get time of day: Operation not permitted
pihole | sudo: error initializing audit plugin sudoers_audit
The query log is showing tha it's 1969:
The DNS is resolving but never seen this happen before with docker and I have 3 other instances running with the same configs on various Synolgoy devices and not seeing this.
Update:
I found this article:
The reason I found this article is that I found CRON using 100% CPU when running Pi-hole in the container. The resolution was to run a backport of libseccomp2.
Here is where I got the instructions for the back port:
https://github.com/pi-hole/docker-pi-hole/issues/1042#issuecomment-1086728157
After doing the backport I am back to normal
