I googled for over an hour I don't know what is wrong, my install crashes after checking for whiptail.
See log:
set -e
tmpLog=/tmp/pihole-install.log
instalLogLoc=/etc/pihole/install.log
setupVars=/etc/pihole/setupVars.conf
lighttpdConfig=/etc/lighttpd/lighttpd.conf
webInterfaceGitUrl=https://github.com/pi-hole/AdminLTE.git
webInterfaceDir=/var/www/html/admin
piholeGitUrl=https://github.com/pi-hole/pi-hole.git
PI_HOLE_LOCAL_REPO=/etc/.pihole
PI_HOLE_FILES=(chronometer list piholeDebug piholeLogFlush setupLCD update version gravity uninstall webpage)
PI_HOLE_INSTALL_DIR=/opt/pihole
useUpdateVars=false
IPV4_ADDRESS=
IPV6_ADDRESS=
QUERY_LOGGING=true
INSTALL_WEB=true
++ stty size
++ echo 24 80 -
screen_size='24 80'
++ echo '24 80'
++ awk '{print $1}' -
rows=24
++ echo '24 80'
++ awk '{print $2}' -
columns=80
r=12
c=40
r=20
c=70
skipSpaceCheck=false
reconfigure=false
runUnattended=false
[[ '' != true ]]
main
show_ascii_berry
echo '
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'''ccll:;ll .oooodc
.;cll.;;looo:.
'.;;,. .ccccc:,. :cccclll:. ..,, :ccccclll. ;ooodc 'ccll:;ll .oooodc .;cll.;;looo:. .. ','. .',,,,,,'. .',,,,,,,,,,. .',,,,,,,,,,,,.... ....''',,,,,,,'....... ......... .... ......... .......... .......... .......... .......... ......... .... ......... ........,,,,,,,'...... ....',,,,,,,,,,,,. .',,,,,,,,,'. .',,,,,,'. ..'''.
echo :::
[[ 0 -eq 0 ]]
echo '::: You are root.'
::: You are root. -
distro_check
command -v apt-get
PKG_MANAGER=apt-get
UPDATE_PKG_CACHE='test_dpkg_lock; apt-get update'
PKG_INSTALL=(${PKG_MANAGER} --yes --no-install-recommends install)
PKG_COUNT='apt-get -s -o Debug::NoLocking=true upgrade | grep -c ^Inst || true'
apt-get install --dry-run iproute2
iproute_pkg=iproute2
apt-get install --dry-run php
phpVer=php5
INSTALLER_DEPS=(apt-utils dialog debconf dhcpcd5 git ${iproute_pkg} whiptail)
PIHOLE_DEPS=(bc cron curl dnsmasq dnsutils iputils-ping lsof netcat sudo unzip wget)
PIHOLE_WEB_DEPS=(lighttpd ${phpVer}-common ${phpVer}-cgi)
LIGHTTPD_USER=www-data
LIGHTTPD_GROUP=www-data
LIGHTTPD_CFG=lighttpd.conf.debian
DNSMASQ_USER=dnsmasq
[[ -f /etc/pihole/setupVars.conf ]]
[[ false == true ]]
verifyFreeDiskSpace
echo '::: Verifying free disk space...'
::: Verifying free disk space... -
local required_free_kilobytes=51200
++ df -Pk
++ grep -m1 '/$'
++ awk '{print $4}' -
local existing_free_kilobytes=12389300
[[ 12389300 =~ ^([0-9])+$ ]]
[[ 12389300 -lt 51200 ]]
update_package_cache
echo :::
echo -n '::: Updating local cache of available packages...'
::: Updating local cache of available packages...+ eval 'test_dpkg_lock; apt-get update' -
echo ' done!'
done! -
notify_package_updates_available
echo :::
echo -n '::: Checking apt-get for upgraded packages....'
::: Checking apt-get for upgraded packages....++ eval 'apt-get -s -o Debug::NoLocking=true upgrade | grep -c ^Inst || true'
+++ apt-get -s -o Debug::NoLocking=true upgrade
+++ grep -c '^Inst'
+++ true -
updatesToInstall=0
echo ' done!'
done! -
echo :::
++ uname -r -
[[ -d /lib/modules/4.9.24-v7+ ]]
[[ 0 -eq 0 ]]
echo '::: Your system is up to date! Continuing with Pi-hole installation...'
::: Your system is up to date! Continuing with Pi-hole installation... -
install_dependent_packages 'INSTALLER_DEPS[@]'
argArray1=("${!1}")
declare -a argArray1
declare -a installArray
command -v debconf-apt-progress
for i in '"${argArray1[@]}"'
echo -n '::: Checking for apt-utils...'
::: Checking for apt-utils...+ dpkg-query -W '-f=${Status}' apt-utils -
grep 'ok installed'
echo ' installed!'
installed! -
echo -n '::: Checking for dialog...'
::: Checking for dialog...+ dpkg-query -W '-f=${Status}' dialog -
grep 'ok installed'
echo ' added to install list!'
added to install list! -
installArray+=("${i}")
echo -n '::: Checking for debconf...'
::: Checking for debconf...+ dpkg-query -W '-f=${Status}' debconf -
grep 'ok installed'
echo ' installed!'
installed! -
echo -n '::: Checking for dhcpcd5...'
::: Checking for dhcpcd5...+ dpkg-query -W '-f=${Status}' dhcpcd5 -
grep 'ok installed'
echo ' installed!'
installed! -
echo -n '::: Checking for git...'
::: Checking for git...+ dpkg-query -W '-f=${Status}' git -
grep 'ok installed'
echo ' installed!'
installed! -
echo -n '::: Checking for iproute2...'
::: Checking for iproute2...+ dpkg-query -W '-f=${Status}' iproute2 -
grep 'ok installed'
echo ' installed!'
installed! -
echo -n '::: Checking for whiptail...'
::: Checking for whiptail...+ dpkg-query -W '-f=${Status}' whiptail -
grep 'ok installed'
echo ' installed!'
installed! -
[[ 1 -gt 0 ]]
test_dpkg_lock
i=0
fuser /var/lib/dpkg/lock
return 0
debconf-apt-progress -- apt-get --yes --no-install-recommends install dialog
