Ads on google should be blocked. Im not talking about videos. I read another post about a guy who had the same issue and he was asked for the log so here it is: https://tricorder.pi-hole.net/QI9FbjIt/
Just so I’m understanding, does my log look good? I’m just concerned that it’s an issue with pihole because I’m only getting a low block rate but I see ads all over the place
First, ensure the client(s) are using Pi-hole for DNS.
Tail the pihole log, open a browser or app on a device and see if you get a sudden blast of DNS queries in the log. The queries should also be shown in the query log on the web admin GUI.
Also, from a client that you believe should be connected to the Pi-Hole for DNS, from the command prompt or terminal on that client (and not via ssh or Putty to the Pi), what is the output of
