I am unable to block domains on PiHole
I installed Pi-hole on Raspberry Pi. My client is shown as connected but unable to block domains and are also not shown in logs. I have added Pi address as DNS server on my macbook.
I had ngnix setup which I have stopped and did fresh install of Pi-hole.
When I added google.com to blacklist to check if things are working. It shouldn't have loaded in browser
But it's loading.
https://tricorder.pi-hole.net/FLL7LeP6
It appears the client is not using Pi-hole for DNS.
From the same client that you believe should be connected to the Pi-Hole for DNS, from the command prompt or terminal on that client (and not via ssh or Putty to the Pi), what is the output of
nslookup pi.hole
nslookup flurry.com
nslookup google.com 172.22.0.2
➜ ~ nslookup pi.hole
Server: 127.0.2.2
Address: 127.0.2.2#53
** server can't find pi.hole: NXDOMAIN
➜ ~ nslookup flurry.com
Server: 127.0.2.2
Non-authoritative answer:
Address: 212.82.100.150
Address: 98.136.103.23
Address: 74.6.136.150
➜ ~ nslookup google.com 172.22.0.2
This client is not using Pi-hole for DNS, it is using a loopback IP.
How is your docker container opening the docker ports to the LAN?
PORT CONFIGURATION
0.0.0.0:53  53/tcp
:::53  53/tcp
0.0.0.0:53  53/udp
:::53  53/udp
0.0.0.0:67  67/udp
:::67  67/udp
0.0.0.0:80  80/tcp
:::80  80/tcp
using pi-hole_default configuration
How did you started the container?
Can you please port the docker run command or the composer file used to start it?
version: "3"
services:
  pihole:
    container_name: pihole
    image: pihole/pihole:latest
    ports:
      - "53:53/tcp"
      - "53:53/udp"
      - "67:67/udp" # Only required if you are using Pi-hole as your DHCP server
      - "80:80/tcp"
    environment:
      TZ: 'Asia/Kolkata'
      WEBPASSWORD: 'example_password'
    volumes:
      - './etc-pihole:/etc/pihole'
    #   https://github.com/pi-hole/docker-pi-hole#note-on-capabilities
    cap_add:
      - NET_ADMIN # Required if you are using Pi-hole as your DHCP server, else not needed
    restart: unless-stopped
Cloudflare warp was causing the issue. Disabling that fixed the problems
