The issue I am facing:
It is not possible to configure PI hall as a DHCP server when working with Huawei ax3 pro. Constantly gives an error in the settings that it cannot be assigned by the server due to an IP conflict of the same local network when connecting via LAN.
Not at all familiar with your router, but to me it seems as if you have both your router handing DHCP for the same IP range as your Pi-hole. You can have more than one server handling DHCP, but they would have to be serving separate IP ranges/subnets.
If you want to use Pi-hole as your DHCP server, I would suggest you figure out how to disable DHCP on your router, as that is a simpler solution.
