Https:// Top Domain exclusion in API
I have a sleepnumber bed that sends telemetry data on our sleep habits and I can view that data on the Sleep Number ap.
I see https://prod-dg.sleepiq.sleepnumber.com in my Top Domain List and want to exclude it but when I enter it in, i get the following error
Top Domains/Ads entry https://prod-dg.sleepiq.sleepnumber.com is invalid (use only domains)
I think it doesn't like the https:// but excluding it doesn't' result in it being removed either.
Any suggestions on how I can get these removed from the API top domains?
Can you post a screenshot(s) of what you are seeing on your web GUI? Thanks.
Here's how it appears in the Query list
When I try to put it on the API exclusion list, i get the following error.
If I remove the HTTPS:// and just enter prod-dg.sleepiq.sleepnumber.com in the exclusion, I don't get an errore but, it still shows up as a Top Domain
The Sleep Number bed somehow is sending an invalid domain to the DNS server (at least it seems that way). Find the queries it sends in the dnsmasq log (/var/log/pihole.log) and share what you find.
Terminal commands that may help search your log:
sudo grep -i sleepnumber /var/log/pihole.log
or search for queries from that device:
sudo grep -i [IP address here] /var/log/pihole.log
Here's a excerpt from the log
Oct 11 07:07:02 dnsmasq[13446]: 157 192.168.0.214/51327 query[A] https://prod-dg.sleepiq.sleepnumber.com from 192.168.0.214
Oct 11 07:07:02 dnsmasq[13446]: 157 192.168.0.214/51327 forwarded https://prod-dg.sleepiq.sleepnumber.com to 208.67.220.220
Oct 11 07:07:02 dnsmasq[13446]: 158 192.168.0.214/51327 query[AAAA] https://prod-dg.sleepiq.sleepnumber.com from 192.168.0.214
Oct 11 07:07:02 dnsmasq[13446]: 158 192.168.0.214/51327 forwarded https://prod-dg.sleepiq.sleepnumber.com to 208.67.220.220
Oct 11 07:07:02 dnsmasq[13446]: 157 192.168.0.214/51327 reply https://prod-dg.sleepiq.sleepnumber.com is NXDOMAIN
Oct 11 07:07:02 dnsmasq[13446]: 158 192.168.0.214/51327 reply https://prod-dg.sleepiq.sleepnumber.com is NXDOMAIN
Oct 11 07:07:02 dnsmasq[13446]: 159 192.168.0.214/42348 query[A] https://prod-dg.sleepiq.sleepnumber.com.MyHouse from 192.168.0.214
Oct 11 07:07:02 dnsmasq[13446]: 159 192.168.0.214/42348 forwarded https://prod-dg.sleepiq.sleepnumber.com.MyHouse to 192.168.0.1
Oct 11 07:07:02 dnsmasq[13446]: 160 192.168.0.214/42348 query[AAAA] https://prod-dg.sleepiq.sleepnumber.com.MyHouse from 192.168.0.214
Oct 11 07:07:02 dnsmasq[13446]: 160 192.168.0.214/42348 forwarded https://prod-dg.sleepiq.sleepnumber.com.MyHouse to 192.168.0.1
Oct 11 07:07:02 dnsmasq[13446]: 159 192.168.0.214/42348 reply https://prod-dg.sleepiq.sleepnumber.com.MyHouse is NXDOMAIN
Oct 11 07:07:02 dnsmasq[13446]: 160 192.168.0.214/42348 reply https://prod-dg.sleepiq.sleepnumber.com.MyHouse is NXDOMAIN
Oct 11 07:07:02 dnsmasq[13446]: 161 192.168.0.214/50947 reply prod-dg-legacy.sleepiq.sleepnumber.com is <CNAME>
Oct 11 07:07:02 dnsmasq[13446]: 162 192.168.0.214/50947 reply prod-dg-legacy.sleepiq.sleepnumber.com is <CNAME>
Oct 11 07:22:02 dnsmasq[13731]: 496 192.168.0.214/40126 query[A] https://prod-dg.sleepiq.sleepnumber.com from 192.168.0.214
Oct 11 07:22:02 dnsmasq[13731]: 496 192.168.0.214/40126 forwarded https://prod-dg.sleepiq.sleepnumber.com to 208.67.220.220
Oct 11 07:22:02 dnsmasq[13731]: 497 192.168.0.214/40126 query[AAAA] https://prod-dg.sleepiq.sleepnumber.com from 192.168.0.214
Oct 11 07:22:02 dnsmasq[13731]: 497 192.168.0.214/40126 forwarded https://prod-dg.sleepiq.sleepnumber.com to 208.67.220.220
Oct 11 07:22:02 dnsmasq[13731]: 496 192.168.0.214/40126 reply https://prod-dg.sleepiq.sleepnumber.com is NXDOMAIN
Oct 11 07:22:02 dnsmasq[13731]: 497 192.168.0.214/40126 reply https://prod-dg.sleepiq.sleepnumber.com is NXDOMAIN
Oct 11 07:22:02 dnsmasq[13731]: 498 192.168.0.214/50073 query[A] https://prod-dg.sleepiq.sleepnumber.com.MyHouse from 192.168.0.214
Oct 11 07:22:02 dnsmasq[13731]: 498 192.168.0.214/50073 forwarded https://prod-dg.sleepiq.sleepnumber.com.MyHouse to 192.168.0.1
Oct 11 07:22:02 dnsmasq[13731]: 499 192.168.0.214/50073 query[AAAA] https://prod-dg.sleepiq.sleepnumber.com.MyHouse from 192.168.0.214
Oct 11 07:22:02 dnsmasq[13731]: 499 192.168.0.214/50073 forwarded https://prod-dg.sleepiq.sleepnumber.com.MyHouse to 192.168.0.1
Oct 11 07:22:02 dnsmasq[13731]: 498 192.168.0.214/50073 reply https://prod-dg.sleepiq.sleepnumber.com.MyHouse is NXDOMAIN
Oct 11 07:22:02 dnsmasq[13731]: 499 192.168.0.214/50073 reply https://prod-dg.sleepiq.sleepnumber.com.MyHouse is NXDOMAIN
Oct 11 07:22:02 dnsmasq[13731]: 500 192.168.0.214/56121 reply prod-dg-legacy.sleepiq.sleepnumber.com is <CNAME>
Oct 11 07:22:02 dnsmasq[13731]: 501 192.168.0.214/56121 reply prod-dg-legacy.sleepiq.sleepnumber.com is <CNAME>
Oct 11 07:37:02 dnsmasq[13731]: 1286 192.168.0.214/56801 query[A] https://prod-dg.sleepiq.sleepnumber.com from 192.168.0.214
Oct 11 07:37:02 dnsmasq[13731]: 1286 192.168.0.214/56801 forwarded https://prod-dg.sleepiq.sleepnumber.com to 208.67.222.222
Oct 11 07:37:02 dnsmasq[13731]: 1287 192.168.0.214/56801 query[AAAA] https://prod-dg.sleepiq.sleepnumber.com from 192.168.0.214
Oct 11 07:37:02 dnsmasq[13731]: 1287 192.168.0.214/56801 forwarded https://prod-dg.sleepiq.sleepnumber.com to 208.67.222.222
Oct 11 07:37:02 dnsmasq[13731]: 1286 192.168.0.214/56801 reply https://prod-dg.sleepiq.sleepnumber.com is NXDOMAIN
Oct 11 07:37:02 dnsmasq[13731]: 1287 192.168.0.214/56801 reply https://prod-dg.sleepiq.sleepnumber.com is NXDOMAIN
Oct 11 07:37:02 dnsmasq[13731]: 1288 192.168.0.214/51297 query[A] https://prod-dg.sleepiq.sleepnumber.com.MyHouse from 192.168.0.214
Oct 11 07:37:02 dnsmasq[13731]: 1288 192.168.0.214/51297 cached https://prod-dg.sleepiq.sleepnumber.com.MyHouse is NXDOMAIN
Oct 11 07:37:02 dnsmasq[13731]: 1289 192.168.0.214/51297 query[AAAA] https://prod-dg.sleepiq.sleepnumber.com.MyHouse from 192.168.0.214
Oct 11 07:37:02 dnsmasq[13731]: 1289 192.168.0.214/51297 cached https://prod-dg.sleepiq.sleepnumber.com.MyHouse is NXDOMAIN
Oct 11 07:37:02 dnsmasq[13731]: 1290 192.168.0.214/52595 reply prod-dg-legacy.sleepiq.sleepnumber.com is <CNAME>
Oct 11 07:37:02 dnsmasq[13731]: 1291 192.168.0.214/52595 reply prod-dg-legacy.sleepiq.sleepnumber.com is <CNAME>
Pi-hole is acting correctly in this case. It received a query from a client, forwarded it up, and since it was a bad request, the upstream sent an NXDOMAIN response, which Pi-hole returned to the client. You can try manually entering the URL into this /etc/pihole/setupVars.conf setting:
API_EXCLUDE_DOMAINS=https://prod-dg.sleepiq.sleepnumber.com
Perfect. Manually adding it to setupVars.conf worked!
Thanks!
A further option if you want to never see this client in your Pi-Hole and you are using the DHCP server in your Pi-Hole - exclude that client from Pi-Hole and give that client a third party DNS address.
I do have a separate VLAN for my "No-Pihole" clients but, it's currently restricted to wired clients only. I didn't wan't to set up a separate SSID for this one wireless client just to give a different DNS via DHCP for this one nuisance client.. I even consider how I might manually assign DNS to the bed but, there isn't exactly a customer facing user interface for that.
