When I hit a particular https url, I expect the page to load. Unfortunately, due to pihole, it fails and says page not found.
Doing a more thorough analysis led me to this root cause.
> $ nmap --reason pointieststick.wordpress.com -p443 -Pn
> Starting Nmap 7.70 ( https://nmap.org ) at 2018-10-09 02:17 EDT
> Nmap scan report for pointieststick.wordpress.com (192.0.78.12)
> Host is up, received user-set.
> Other addresses for pointieststick.wordpress.com (not scanned): 192.0.78.13
> PORT STATE SERVICE REASON
> 443/tcp filtered https no-response
> Nmap done: 1 IP address (1 host up) scanned in 2.08 seconds
> [xxx@yyy-xxx ~]$ nmap --reason github.com -p443 -Pn
> Nmap scan report for github.com (192.30.253.113)
> Other addresses for github.com (not scanned): 192.30.253.112
> rDNS record for 192.30.253.113: lb-192-30-253-113-iad.github.com
> Nmap done: 1 IP address (1 host up) scanned in 2.09 seconds
I get back a 'No-response' from the sites in question. Is there a way to fix this ? Reverting back to the original list also doesn't help. This is rendering my pihole pretty much useless
Debug Token: leqeyxss3h
PS
I'm using dnscrypt2 with pi-hole and running this on a Ubuntu 18.04 machine. Not sure if this info is relevant, but throwing it out there. Tried without dnscrypt also and it didn't help
_
