So my problem is that when im loading websites with https content, the https domains take forever to timeout which slows down everything which is really annoying.
So I already configured ufw to reject port 443 traffic and allowed traffic for port 22 and 80.
I also tried flushing my dns cache.
eg. when I try to connect to https://googletagservices.com/ I get an timeout.
So I hope you guys can help me. ![]()
pi-hole -d output:
::: Beginning Pi-hole debug at Sun 23 Jul 21:48:32 CEST 2017!
::: This process collects information from your Pi-hole, and optionally uploads
::: it to a unique and random directory on tricorder.pi-hole.net.
::: NOTE: All log files auto-delete after 48 hours and ONLY the Pi-hole developers
::: can access your data via the given token. We have taken these extra steps to
::: secure your data and will work to further reduce any personal information gathered.
::: Please read and note any issues, and follow any directions advised during this process.
::: ---= Detecting Installed Package Versions:
::: Pi-hole: v3.1.4 (master:v3.1.4-0-gb0ecedd)
::: Pi-hole Dashboard: v3.1 (master:v3.1-0-gf204b71-dirty)
::: lighttpd/1.4.35
::: PHP 7.0.21-1+0~20170706092253.2+jessie~1.gbp57c738 (cli) (built: Jul 12 2017 03:33:36) ( NTS )
::: ---= Detecting existence of /etc/pihole/setupVars.conf:
::: File exists, parsing...done and was successfully sourced
::: ---= Detecting installed OS Distribution
::: ---= Checking processor variety
::: ---= Checking IPv6 Stack
::: IPv6 addresses located on eth0
::: Pinging default IPv6 gateway: ::: Gateway responded.
::: Pinging Internet via IPv6: ::: Query responded.
::: ---= Checking IPv4 Stack
::: IPv4 addresses located on eth0
::: Pinging default IPv4 gateway: ::: Gateway responded.
::: Pinging Internet via IPv4: ::: Query responded.
::: ---= Daemon Process Information
::: Checking http port for lighttpd listener.
::: Correctly configured.
::: Checking domain port for dnsmasq listener.
::: Checking 4711 port for pihole-FTL listener.
::: ---= Processes Check
::: Logging status of lighttpd, dnsmasq and pihole-FTL...
::: ---= Resolver Functions Check (IPv4)
::: ---= Resolver Functions Check (IPv6)
::: Checking for necessary lighttpd files.
::: ---= Detecting existence of /etc/lighttpd/lighttpd.conf:
::: ---= Detecting existence of /var/log/lighttpd/error.log:
::: ---= Detecting existence of /etc/dnsmasq.conf:
::: ---= Detecting contents of /etc/dnsmasq.d/*:
::: ---= File /etc/dnsmasq.d/01-pihole.conf found
::: Parsing...done
::: ---= File /etc/dnsmasq.d/README found
::: Parsing...done
::: ---= Detecting existence of /etc/pihole/whitelist.txt:
::: ---= Detecting existence of /etc/pihole/blacklist.txt:
::: /etc/pihole/blacklist.txt not found!
::: ---= Detecting existence of /etc/pihole/adlists.list:
::: ---= Analyzing gravity.list
::: ---= Analyzing pihole.log
::: ---= Analyzing pihole-FTL.log
::: --= User Action Required =--
::: Try loading a site that you are having trouble with now from a client web browser..
::: (Press CTRL+C to finish logging.)
::: ---= pihole.log
::: Logging will automatically teminate in 60 seconds
::: Finshed debugging!.
::: The debug log can be uploaded to tricorder.pi-hole.net for sharing with developers only.
::: Would you like to upload the log? [y/N] y
::: ---=== Your debug token is : t9znd5idp2 Please make a note of it. ===---
::: Contact the Pi-hole team with your token for assistance.
::: Thank you.
::: A local copy of the Debug log can be found at : /var/log/pihole_debug.log
