Pi-Hole installed on Raspberry Pi4 with UnBound on port 5353 as the sole DNS server
http://pi.hole/admin should load the Pi-Hole admin page.
page does not resolve, and I get the error ERR_CONNECTION_REFUSED
https://tricorder.pi-hole.net/71dp1ykdz9/
local.list contents are
192.168.1.254 pi.hole
pi@PiBrain:/etc/pihole $ nslookup 192.168.1.254
254.1.168.192.in-addr.arpa name = pi.hole.
pi@PiBrain:/etc/pihole $ nslookup pi.hole 192.168.1.254
Server: 192.168.1.254
Address: 192.168.1.254#53
pi@PiBrain:/etc/pihole $ dig pi.hole/admin
; <<>> DiG 9.11.5-P4-5.1+deb10u1-Raspbian <<>> pi.hole/admin
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 64187
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;pi.hole/admin. IN A
;; AUTHORITY SECTION:
. 2815 IN SOA a.root-servers.net. nstld.verisign-grs.com. 2020082602 1800 900 604800 86400
;; Query time: 73 msec
;; WHEN: Wed Aug 26 19:10:15 EDT 2020
;; MSG SIZE rcvd: 117
UnBound troubleshooting
pi@PiBrain:/etc $ sudo service unbound status
Active: active (running) since Wed 2020-08-26 16:33:21 EDT; 2h 51min ago
Docs: man:unbound(8)
Process: 556 ExecStartPre=/usr/lib/unbound/package-helper chroot_setup (code=exited, status=0/SUCCESS)
Process: 582 ExecStartPre=/usr/lib/unbound/package-helper root_trust_anchor_update (code=exited, status=0/SUCCESS)
Main PID: 594 (unbound)
Tasks: 1 (limit: 3862)
CGroup: /system.slice/unbound.service
└─594 /usr/sbin/unbound -d
Aug 26 16:33:17 PiBrain systemd[1]: Starting Unbound DNS server...
Aug 26 16:33:20 PiBrain package-helper[582]: /var/lib/unbound/root.key has content
Aug 26 16:33:20 PiBrain package-helper[582]: fail: the anchor is NOT ok and could not be fixed
Aug 26 16:33:21 PiBrain unbound[594]: [594:0] info: start of service (unbound 1.9.0).
Aug 26 16:33:21 PiBrain systemd[1]: Started Unbound DNS server.
pi@PiBrain:/etc $ dig pi-hole.net @127.0.0.1 -p 5353
; <<>> DiG 9.11.5-P4-5.1+deb10u1-Raspbian <<>> pi-hole.net @127.0.0.1 -p 5353
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 1875
;pi-hole.net. IN A
pi-hole.net. 3600 IN A 192.124.249.118
;; Query time: 99 msec
;; SERVER: 127.0.0.1#5353(127.0.0.1)
;; WHEN: Wed Aug 26 19:29:36 EDT 2020
;; MSG SIZE rcvd: 56
