HTTP 500 error for ‘Settings’ page
my pi-hole work fine but the settings page return a code 500
in ssh i try "pihole -up" without success.
pi@raspberrypi:~ $ pihole -up
  [i] Checking for updates...
  [i] Pi-hole Core:     update available
  [i] Web Interface:    update available
  [i] FTL:              update available
  [i] Pi-hole core files out of date, updating local repo.
  [✓] Check for existing repository in /etc/.pihole
  [i] Update repo in /etc/.pihole...HEAD est maintenant à 56cd7c4d Merge pull request #3549 from pi-hole/release/v5.1.1
  [✓] Update repo in /etc/.pihole
  [i] If you had made any changes in '/etc/.pihole/', they have been stashed using 'git stash'
  [i] Pi-hole Web Admin files out of date, updating local repo.
  [✓] Check for existing repository in /var/www/html/admin
  [✓] Update repo in /var/www/html/admin
  [i] If you had made any changes in '/var/www/html/admin/', they have been stashed using 'git stash'
  [i] FTL out of date, it will be updated by the installer.
  [✓] Root user check
        .ccccc:,.
         :cccclll:.      ..,,
          :ccccclll.   ;ooodc
           'ccll:;ll .oooodc
             .;cll.;;looo:.
  [✗] Update local cache of available packages
  Error: Unable to update package cache. Please try "apt-get update"
pi@raspberrypi:~ $ apt-get update
Erreur de segmentation
RPI 2
https://tricorder.pi-hole.net/5wiwh540r5
sorry ok after reboot... i don't understand
