Hello
I would like to use teleporter command on a docker host for a specific pihole container.
With that it would be easy to save pihole backup's on a nas for instance.
Thx
Hello
Thx
Run the following command from within your Pi-hole container:
sudo pihole-FTL --teleporter
Is there a possibility to do following?
docker exec -it container pihole-FTL --teleporter
to save the zip on the docker host?
Sure, save the zip file in the mounted storage.
leaves the zipfile in the current working directory. If you have /etc/pihole/
mounted in as a storage location then run
docker exec --workdir /etc/pihole pihole pihole-FTL --teleporter
