How to set a proxy for curl
Hello,
On my network, all servers must go through a proxy for any outgoing request. Pi-hole relies heavily on curl to load new version of the system and to update the ban lists.
I could load the lists at install time because I had set-up the proxy manually in the shell, but since the system is running, where can I configure Pi-hole and curl to use my proxy for all requests?
I have created the file /root/.curlrc but it is not even read by Pi-hole system. Same thing with /.curlrc
Si how do I define a proxy in Pi-hole?
Thanks in advance,
Olivier
There isn't support for a proxy in Pi-hole, you will have to configure curl or your network settings to handle that.
There isn’t support for a proxy in Pi-hole, you will have to configure curl
Thank you.
For curl, I think I have it fixed, a .curlrc file in /root (or in /)
seems to be enough, the update of the gravity files goes through the
proxy.
Now I am left with the automatic check of the latest version of
Pi-Hole each time Pi-Hole is started. It seems it uses git to
load/clone something from github.com
I have installed a .gitconfig file in /root/, /, /var/www/html/admin/,
/var/www/html/admin/.git/, /etc/.pihole, /etc/.pihole/.git/. Either my
.gitconfig file is bogus or I am not targeting right directory (or it
is not using git).
I don't mind configuring the proxy by hand, but I could do with a
little help as to where I should put the configuration.
Thanks in advance,
Olivier
I'm not familiar with adding a proxy to git, but nothing is cloned or fetched through git when checking for updates. The version check is performed by root in a cron job, and uses curl:
Hello.
I’m not familiar with adding a proxy to git, but nothing is cloned or
Any reason why the curl command get a -q option to disable the use of
curl config file?
I tried to modify updatecheck.sh to remove the -q option on the 3
lines calling curl and, sure enough, everything get proxied properly.
A corollary question, I got nothing installed in root cron when
installing Pi-Hole, should I install the call to
/opt/pi-hole/updatecheck.sh manually?
Thanks in advance,
Olivier
I don't know why that option is added, but you can make an issue on GitHub for it.
The cron job is installed to /etc/cron.d/pihole
