How to run different projects with their own frontend?
I'd like to run and maintain multiple projects (PiHole and volkszaehler) on one maschine (here RPi3) with there own frontend
every project on the pi wants to use port 80 and has there prefered server (nginx, php-pm, lighttpd, apache2, etc.
yfoed8prbp
I'm not sure either I run one server with different ports for every project or how to set up supdomains or suppages like 192.168.178.22/admin and 192.168.178.22/volkszaehler
pi@raspberrypi:~ $ cat /etc/lighttpd/lighttpd.conf
# Lighttpd config for Pi-hole
#     FILE AUTOMATICALLY OVERWRITTEN BY PI-HOLE INSTALL/UPDATE PROCEDURE.     #
#              CHANGES SHOULD BE MADE IN A SEPARATE CONFIG FILE:              #
#                         /etc/lighttpd/external.conf                         #
server.modules = (
        "mod_access",
        "mod_accesslog",
        "mod_auth",
        "mod_expire",
        "mod_compress",
        "mod_redirect",
        "mod_setenv",
        "mod_rewrite"
server.error-handler-404    = "pihole/index.php"
server.pid-file             = "/var/run/lighttpd.pid"
accesslog.filename          = "/var/log/lighttpd/access.log"
accesslog.format            = "%{%s}t|%V|%r|%s|%b"
compress.cache-dir          = "/var/cache/lighttpd/compress/"
compress.filetype           = ( "application/javascript", "text/css", "text/html", "text/plain" )
# default listening port for IPv6 falls back to the IPv4 port
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
# Prevent Lighttpd from enabling Let's Encrypt SSL for every blocked domain
#include_shell "/usr/share/lighttpd/include-conf-enabled.pl"
include_shell "find /etc/lighttpd/conf-enabled -name '*.conf' -a ! -name 'letsencrypt.conf' -printf 'include \"%p\"\n' 2>/dev/null"
# If the URL starts with /admin, it is the Web interface
$HTTP["url"] =~ "^/admin/" {
    # Create a response header for debugging using curl -I
        "X-Frame-Options" => "DENY"
    $HTTP["url"] =~ ".ttf$" {
        # Allow Block Page access to local fonts
# Block . files from being served, such as .git, .github, .gitignore
     url.access-deny = ("")
# Add user chosen options held in external file
# This uses include_shell instead of an include wildcard for compatibility
pi@raspberrypi:~ $ cat /etc/pihole/install.log
  [✓] Installing scripts from /etc/.pihole
  [✓] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
  [i] Installing blocking page...
  [✓] Creating directory for blocking page, and copying files
  [✗] Backing up index.lighttpd.html
  [✓] Installing sudoer file
  [✓] Installing latest Cron script
  [✓] Installing latest logrotate script
  [i] Backing up /etc/dnsmasq.conf to /etc/dnsmasq.conf.old
  [✓] man pages installed and database updated
This seems to be more like a feature request?
I don't think so, because I saw in the FAQ that I can run multiple programs.
Can you see why I cant start lighttpd?
Lighttpd cannot start because another process is already on port 80. Run this to see which processes are occupying the ports used by Pi-Hole:
sudo netstat -nltup | grep 'Proto\|:53 \|:67 \|:80 \|:471'
I added 8080 also just in case
pi@raspberrypi:~ $ sudo netstat -nltup | grep 'Proto\|:53 \|:67 \|:80 \|:471 \|:8080'
tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      7383/php
tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      11809/pihole-FTL
tcp6       0      0 :::53                   :::*                    LISTEN      11809/pihole-FTL
udp        0      0 0.0.0.0:53              0.0.0.0:*                           11809/pihole-FTL
udp6       0      0 :::53                   :::*                                11809/pihole-FTL
syslog
Jun 15 01:18:21 raspberrypi lighttpd[26950]: /bin/sh: 1: /usr/share/lighttpd/create-mime.assign.pl: not found
Jun 15 01:18:21 raspberrypi lighttpd[26950]: 2019-06-15 01:18:21: (configfile.c.1461) command "/usr/share/lighttpd/create-mime.assign.pl" exited non-zero: 127
Jun 15 01:18:21 raspberrypi lighttpd[26950]: 2019-06-15 01:18:21: (configfile.c.1289) source: /etc/lighttpd/lighttpd.conf line: 53 pos: 14 parser failed somehow near here: (EOL)
I renamed /usr/share/lighttpd/create-mime.conf.pl to create-mime.assign.pl and did a pihole -r
Now everything is working fine. So far.
