How to rotate logs of Pi-hole hourly and log2ram issue?
The issue I am facing:
It seems I have a high traffic home network, so the pihole.log gets several Gb in size during one day. I want to decrease the log size by running log rotate hourly for the pihole.log file instead of daily. I modified the file /etc/pihole/logrotateand changed daily to hourly. Is it enough? Or I should do some other modifications?
I also have a doubt that the logrotate runs at all for the Pi-hole files after I installed and enabled the log2ram, because I don’t see any new compressed rotated log files after that date for pihole.log. And my pihole.log file gets bigger and bigger until it consumes all my free space and I have to flush it manually. Is there any way to check the logs or status of running the logrotate job for the Pi-hole files?
**Details about my system: **
Debian 13 Trixie in LXC container, standard Pi-hole installation.
cat /etc/pihole/versions
CORE_VERSION=v6.1.4
CORE_BRANCH=master
CORE_HASH=cef7fd4b
GITHUB_CORE_VERSION=v6.1.4
GITHUB_CORE_HASH=cef7fd4b
WEB_VERSION=v6.2.1
WEB_BRANCH=master
WEB_HASH=cc1cc285
GITHUB_WEB_VERSION=v6.2.1
GITHUB_WEB_HASH=c0a237a6
FTL_VERSION=v6.2.3
FTL_BRANCH=master
FTL_HASH=88737f62
GITHUB_FTL_VERSION=v6.2.3
GITHUB_FTL_HASH=bc185680
cat /etc/pihole/logrotate
/var/log/pihole/pihole.log {
su root root
hourly
copytruncate
rotate 25
compress
delaycompress
notifempty
nomail
/var/log/pihole/FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
/var/log/pihole/webserver.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
ls -lsh /var/log/pihole/
total 640K
8.0K -rw-r----- 1 pihole pihole 5.0K Sep  5 08:49 FTL.log
4.0K -rw-r----- 1 pihole pihole    2 Sep  5 08:29 FTL.log.1
4.0K -rw-r----- 1 pihole pihole 1.9K Sep  3 03:00 FTL.log.2.gz
4.0K -rw-r----- 1 pihole pihole 1.8K Sep  2 03:00 FTL.log.3.gz
196K -rw-r----- 1 pihole pihole 196K Sep  5 08:52 pihole.log
400K -rw-r----- 1 pihole pihole 398K Aug 28 03:00 pihole.log.6.gz
8.0K -rw-r----- 1 pihole pihole 4.2K Aug 31 07:17 pihole_updateGravity.log
4.0K -rw-r----- 1 pihole pihole  102 Sep  5 08:29 webserver.log
4.0K -rw-r----- 1 pihole pihole    2 Sep  5 08:29 webserver.log.1
4.0K -rw-r----- 1 pihole pihole  221 Aug 31 03:00 webserver.log.2.gz
4.0K -rw-r----- 1 pihole pihole  111 Aug 29 09:44 webserver.log.3.gz
df -h
/dev/loop0      8.8G  6.4G  2.0G  77% /
none            492K  4.0K  488K   1% /dev
devtmpfs        4.0M     0  4.0M   0% /dev/tty
tmpfs            47G  2.1M   47G   1% /dev/shm
tmpfs            19G  120K   19G   1% /run
tmpfs            47G     0   47G   0% /tmp
tmpfs           5.0M     0  5.0M   0% /run/lock
log2ram         5.0G   44M  5.0G   1% /var/log
tmpfs           9.4G  8.0K  9.4G   1% /run/user/0
top
top - 08:55:57 up 44 min,  1 user,  load average: 0.00, 0.00, 0.13
Tasks:  26 total,   1 running,  25 sleeping,   0 stopped,   0 zombie
%Cpu(s): 10.0 us,  0.0 sy,  0.0 ni, 90.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   6144.0 total,   5177.7 free,     88.5 used,    923.0 buff/cache
MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6055.5 avail Mem
I installed log2ram changed from the default configuration to use 5 Gb RAM for the logs to optimize the SSD writing and wear.
This very unusual in a home network.
Before starting to rotate logs, we need to know why the logs are so big.
This can be a result of a high number of devices (in this case log rotation will help you), but it can also be caused by a DNS loop or something else caused by a config issue.
I'm not sure if my network is considered to be big to generate so much log size or not.
I have a total of around 40 devices (phones, virtual machines, IP cameras, etc.).
However, today I see that my log size is just 5 Mb for 8 hours of work after logs flushing.
Could it be that today I run command pihole -f instead of manually deleting the log file as I usually did it.
Another idea is that sometimes my Internet connection goes down, could it lead to excessive logs writing?
The debug log is here https://tricorder.pi-hole.net/OK1dAHHD/
Thank you!
That depends on the apps/services on your devices.
Some apps will keep trying, again and again, to connect to a domain even after several failures. Sometimes these apps will increase the logs in case of Internet failure because the domain can't be reach until the Internet is back.
It seems that's exactly the behavior of my IP cameras. They keep trying to reach the remote control center every 5 seconds again and again. And they don't care if the network is down...
I had a similar experience when I turned off my Internet 3 months ago but left the router on for the LAN, with Pi-hole and a few other devices still on there but unable to reach anything external.
This wasn't a problem because I was using a mobile hotspot on a separate 172/12 subnet for the one computer that really did need external access.
After a couple of months (~ 8 weeks) I set up another Pi as a NAT gateway to the hotspot and used it to temporarily replace the router, to bring the original LAN subnet back online, to solve a specific problem with a device.
At this point the Pi-hole was back up and once again able to be used. However it wasn't working, FTL would not start and Unbound also no longer worked.
After some digging I found the card was full with ~16 GB of logs. Inspecting those found various devices, but especially Unbound itself and the Pi OS filling it with entries every few seconds, and this was going on for ~ 8 weeks with seemingly no rotation.
I wasn't able to get Unbound working so disabled it and switched to Cloudflare's DNS in Pi-hole, and I purged the logs as it was more important to get it back up and running in some usable form than diagnose what had happened.
It's now been working for around ~4 weeks in this slightly crippled form but has solved the problem here. Once I'm back on a normal connection in a few weeks I'll nuke the card, test it's reliable, and re-image with the latest Pi OS and a fresh build of Pi-hole and Unbound.
TL;DR – the OS itself as I've seen, and as you've seen various IoT devices, can be quite noisy if they don't get their own way and find a way to call home for some length of time, even with what you might describe as a normal network. The mere act of preventing them from their chatter can make them become very antisocial, hammering the DNS and gateway 24/7.
Thank you for sharing your experience! I have the same feeling that when Internet is down my devices go to panic mode and spam the DNS logs. I will run some tests next week by plugging off the cable. What surprises me that log rotation did not run in my case. Yet I'm not sure if it's related.
I haven't got that far yet, but you may need to check which elements of logrotate (e.g. hourly rotation) are supplied by the pi-hole software and which by the base OS on which it is installed.
