Hello,
I am new around here but I've tried to find the answer to my question (here and on various tutorials on youtube) and it seems every guide and tutorial concentrates on configuring Pi-Hole, but none on where to stick which cable in...
I am planning to use Pi-Hole (Raspberry Pi 3 B) in it's simplest use case, blocking ads etc. for my entire house network. My setup is that I have a modem/router from my ISP (let's call it a "modem"), which has wifi disabled and which is connected with an ethernet cable to a wifi router (Netgear), which provides signal for the entire house.
My simple question is - how do I physically connect Pi to work on my network? Do I connect it with an ethernet cable to the ISP modem or to the Netgear wifi router? Or do I not use the ethernet cable at all? My guess is that I need to connect it to Netgear with an ethernet cable. Am I correct?
I think I can figure out the rest (DNS etc.) (famous last words ![]()
Thanks!
IO
