Hello,
first of all I want to thank you for this great software, which is possible to run on a small device like my raspberry pi 2 b alongside with other services.
Unfortunatly I ignored the top rule "Never touch a running system" and tried to major update my pihole v5 setup to v6 and for now nothing is running anymore.
Because I dont't want to make a fresh install with newest raspbian version and broke the other sevices which are running for 5 years now as well, I tried to get the an old version of pi-hole. But, as I understand it correct, this is not intended neither possible.
My next approach was to completly uninstall / clean pihole from my system and install pihole in a docker container which should be more comfortable.
Because I don't found explanations with a internet search I have made this post.
Here is the lsb_release output:
root@raspberrypi:~# lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 9.4 (stretch)
Release: 9.4
Codename: stretch
Things I already did:
pihole -uninstall
root@raspberrypi:~# pihole uninstall
[?] Are you sure you would like to remove Pi-hole? [y/N] y
[✓] Root user check
[✓] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[i] SELinux not detected
[✓] Checking apt-get for upgraded packages... 189 updates available
[i] It is recommended to update your OS after installing the Pi-hole!
[✗] Building dependency package pihole-meta.deb
Error: Building pihole-meta.deb failed.
phile -r
root@raspberrypi:~# pihole -r
[✓] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
root@raspberrypi:~# pihole -d
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2025-04-20:11:59:20 debug log has been initialized.
[i] Core: v6.0.6 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Remotes: origin https://github.com/pi-hole/pi-hole.git (fetch)
origin https://github.com/pi-hole/pi-hole.git (push)
[i] Branch: master
[i] Commit: v6.0.6-0-g0f7803b
[i] Web: v6.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Remotes: origin https://github.com/pi-hole/AdminLTE.git (fetch)
origin https://github.com/pi-hole/AdminLTE.git (push)
[i] Branch: master
[i] Commit: v6.1-0-g1eaddca8
[✓] FTL: v5.2 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] 1.4.45
[i] 7.0.33
[✓] Distro: Raspbian
[✗] Version: 9
[✗] Error: Raspbian is supported but version 9 is currently unsupported (https://docs.pi-hole.net/main/prerequisites/)
*** [ DIAGNOSING ]: SELinux
*** [ DIAGNOSING ]: Processor
[✓] armv7l
192.168.0.234/24 matches the IP found in /etc/pihole/setupVars.conf
fe80::ba27:ebff:fef8:3a9f does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[i] Default IPv4 gateway: 192.168.0.1
* Pinging 192.168.0.1...
[✓] Gateway responded.
*:5232 python3 (IPv4)
127.0.0.1:8010 python3 (IPv4)
*:22 sshd (IPv4)
*:22 sshd (IPv6)
[✗] Failed to resolve zamowienie24.icu via localhost (127.0.0.1)
[✗] Failed to resolve zamowienie24.icu via Pi-hole (192.168.0.234)
[✓] doubleclick.com is 142.251.37.14 via a remote, public DNS server (8.8.8.8)
[✗] lighttpd daemon is inactive
[✗] pihole-FTL daemon is failed
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.0.234/24
IPV6_ADDRESS=
PIHOLE_DNS_1=192.168.0.1
PIHOLE_DNS_2=192.168.0.1
QUERY_LOGGING=false
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
BLOCKING_ENABLED=true
[✗] Web interface X-Header: X-Header does not match or could not be retrieved.
*** [ DIAGNOSING ]: Gravity List and Database
-rw-rw-r-- 1 pihole pihole 8761344 Apr 20 04:09 /etc/pihole/gravity.db
*** [ DIAGNOSING ]: Info table
property value
version 12
updated 1745114952
gravity_count 143684
Last gravity run finished at: So 20. Apr 04:09:12 CEST 2025
----- First 10 Gravity Domains -----
localhost.localdomain
ad-assets.futurecdn.net
ck.getcookiestxt.com
eu1.clevertap-prod.com
wizhumpgyros.com
coccyxwickimp.com
webmail-who-int.000webhostapp.com
010sec.com
01mspmd5yalky8.com
0byv9mgbn0.com
*** [ DIAGNOSING ]: Groups
id enabled name date_added date_modified description
0 1 Default 2020-09-06 20:17:06 2020-09-06 20:17:06 The default group
*** [ DIAGNOSING ]: Clients
*** [ DIAGNOSING ]: Adlists
id enabled group_ids address date_added date_modified comment
1 1 0 https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts 2020-09-06 20:17:06 2025-04-18 10:24:01 Migrated from /etc/pihole/adlists.list
4 0 0 https://codeberg.org/hagezi/mirror2/raw/branch/main/dns-blocklists/adblock/light.txt 2025-04-18 10:14:17 2025-04-18 10:24:04 Hagezi Light (https://github.com/hagezi/dns-blockl
5 0 0 https://codeberg.org/hagezi/mirror2/raw/branch/main/dns-blocklists/adblock/multi.txt 2025-04-18 10:23:34 2025-04-18 10:24:05 hagezi normal
-rw-r--r-- 1 root root 48 Apr 20 04:09 /etc/pihole/local.list
192.168.0.234 raspberrypi
192.168.0.234 pi.hole
-rw-r--r-- 1 root root 234 Sep 6 2020 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-rw-r-- 1 pihole root 15 Sep 6 2020 /etc/pihole/pihole-FTL.conf
PRIVACYLEVEL=0
-rw-r--r-- 1 root root 1394 Sep 6 2020 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
local-ttl=2
log-async
server=192.168.0.1
server=192.168.0.1
interface=eth0
server=/use-application-dns.net/
-rw-r--r-- 1 root root 0 Sep 6 2020 /etc/lighttpd/external.conf
-rw-r--r-- 1 root root 4068 Sep 8 2020 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "/pihole/index.php"
server.pid-file = "/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = (
"application/json",
"application/vnd.ms-fontobject",
"application/xml",
"font/eot",
"font/opentype",
"font/otf",
"font/ttf",
"image/bmp",
"image/svg+xml",
"image/vnd.microsoft.icon",
"image/x-icon",
"text/css",
"text/html",
"text/javascript",
"text/plain",
"text/xml"
mimetype.assign = (
".ico" => "image/x-icon",
".jpeg" => "image/jpeg",
".jpg" => "image/jpeg",
".png" => "image/png",
".svg" => "image/svg+xml",
".html" => "text/html; charset=utf-8",
".js" => "text/javascript; charset=utf-8",
".json" => "application/json; charset=utf-8",
".map" => "application/json; charset=utf-8",
".txt" => "text/plain; charset=utf-8",
".eot" => "application/vnd.ms-fontobject",
".otf" => "font/otf",
".ttc" => "font/collection",
".ttf" => "font/ttf",
".woff" => "font/woff",
".woff2" => "font/woff2"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ "\.(eot|otf|tt[cf]|woff2?)$" {
url.access-deny = ("")
expire.url = ( "" => "access plus 0 seconds" )
-rw-r--r-- 1 root root 1754 Sep 6 2020 /etc/cron.d/pihole
9 4 * * 7 root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
00 00 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker local
15 14 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker remote reboot
/var/log/lighttpd does not exist.
ls: Zugriff auf '/var/log/lighttpd' nicht möglich: Datei oder Verzeichnis nicht gefunden
*** [ DIAGNOSING ]: contents of /dev/shm
*** [ DIAGNOSING ]: Locale
LANG=de_DE.UTF-8
ls: Zugriff auf '/var/log/pihole.log' nicht möglich: Datei oder Verzeichnis nicht gefunden
head: '/var/log/pihole.log' kann nicht zum Lesen geöffnet werden: Datei oder Verzeichnis nicht gefunden
-----head of pihole.log------
[✓] ** FINISHED DEBUGGING! **
* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
[?] Would you like to upload the log? [y/N]
* Log will NOT be uploaded to tricorder.
* A local copy of the debug log can be found at: /var/log/pihole_debug.log
Thanks in advance
