Hello,
I forgot to not my pi-hole IP address during the initial install.
How do I find out what it is?
Thanks
Vielen Dank.
It would most likely be the IP of the device you installed Pi-hole on. Try using this to find it:
ip addr
Which one should I use?
- lo
- enol
or - wlp2s0
Thanks for your assistance.
Whichever you chose during install. The IP Pi-hole is using can also be found in /etc/pihole/setupVars.conf
OK, thanks.
I was planning on using ipv6 instead of ipv4.
I assume that will be fine.
