How to disable NTP and IPv6 on v6?
The IPV6: false is now deprecated on v6
I could not find any ntp config etiher.
Look around in /etc/pihole/pihole.toml and you will find everything you need !!! :wink:
All those settings are also available in Expert Mode via the webGUI when you enable them on the top right part of the Settings webpage : You get a new sub-menu called "All Settings" :+1:
Your text is very short and there are no details, but I'm guessing you are talking about the docker environment variable IPV6.
All docker variables were renamed to fit the new settings.
We have a docker "migration" help in our Documentation:
Also, the new README contains many details about the new variables:
Note:
You can also set any FTL configuration using variables using the format FTLCONF_ + FTL option where you replace dots (.) with underscores (_), like that:
To set web interface theme you need to set webserver.interface.theme.
The variable will be: FTLCONF_webserver_interface_theme.
You can find all settings in the /etc/pihole/pihole.toml or looking at Settings > All settings page, on the web interface.
