thobi
February 13, 2019, 8:55pm
1
I'm trying to configure pihole (4.2.1_armhf) for my raspberry pi.
For this I'm configuring with docker-compose.
Everythings works fine.
To preserve my sd card, I want to disable logging. I've turned off logging from the web interface.
However, the pihole.log file is still growing with about 70 lines a minute.
The most promising solution : configuring 01-pihole.conf to disable logging by setting this :
"log-facility=/var/log/pihole.log"
to
"log-facility=-"
My problem is that after editing it, on the docker restart, the file is overwritten and the setting is lost.
How can I disable this log? Is there a synthax to disable this parameter?
Into my docker-compose.yml, i've set those folders :
volumes:
- '${USERDIR}/data/pihole/data:/etc/pihole/'
- '${USERDIR}/data/pihole/dnsmasq.d:/etc/dnsmasq.d'
- '${USERDIR}/data/pihole/log/pihole.log:/var/log/pihole.log'
Thanks for help.
diginc
February 13, 2019, 10:29pm
3
change your volume mounts to
- /dev/null:/var/log/pihole.log
- /dev/null:/var/log/pihole-FTL.log
and any others files that you might find with heavy logging.
You could probably point log-facility=/dev/null as an alternative to docker mounts. I like the consistency of using the volume mounts.
thobi
February 14, 2019, 6:16am
4
Thanks for help! It works!
I've tried this but had a permission denied when using /dev/null.
I've had to remove the /dev/null wrong file with this ->
sudo rm -f /dev/null; sudo mknod -m 666 /dev/null c 1 3
Then nomore permission denied on docker-compose up -d!
Thanks a lot!
If it can help somebody, here is the whole docker-compose.yml ->
version: "3"
services:
pihole:
image: pihole/pihole:4.2.1_armhf
restart: unless-stopped
cap_add:
- NET_ADMIN
dns:
- 127.0.0.1
ports:
- "53:53/tcp"
- "53:53/udp"
- "80:80/tcp"
- "443:443/tcp"
environment:
# enter your docker host IP here
ServerIP: ${SERVER_IP}
TZ: ${TZ}
WEBPASSWORD: ${PIHOLE_PW}
DNS1: 1.1.1.1
DNS2: 1.0.0.1
volumes:
- '${DOCKER_USERDIR}/data/pihole/data:/etc/pihole/'
- '${DOCKER_USERDIR}/data/pihole/dnsmasq.d:/etc/dnsmasq.d'
Has anyone found a solution here? This does not work for me. I have tried adding
- '/dev/null:/var/log/pihole-FTL.log'
to my docker-compose, but it breaks the permissions of the host-os' /dev/null every time the container starts.
I also tried adding
command: "sudo pihole logging off"
to the docker-compose, but it seems that when this command exits 0 as a normal part of the container initialization, it causes s6 to shut everything down. Please help!
