Hi
Noob here, I'm just getting to grips with Linux and am finding the Pi a great little machine to work with. I'm a network engineer so obviously, this app caught my eye. My home network is 172.16.0.1/24 so a subnet of the 172.x.x.x private range.
I'm using the built-in DHCP server but that obviously uses the mask for the whole 172.x.x.x range, whilst this is ok, it works, but it does make network discoveries and scans take forever. I've looked but can't find how to change the subnet mask in the DHCP options, can one of you nice people point me in the right direction.
Cheers
Leigh
Here is little push.
$ man dnsmasq
DNSMASQ(8) System Manager's Manual DNSMASQ(8)
NAME
dnsmasq - A lightweight DHCP and caching DNS server.
SYNOPSIS
dnsmasq [OPTION]...
DESCRIPTION
dnsmasq is a lightweight DNS, TFTP, PXE, router advertisement and DHCP server. It is intended to provide coupled DNS and DHCP
service to a LAN.
-O, --dhcp-option=[tag:<tag>,[tag:<tag>,]][encap:<opt>,][vi-encap:<enterprise>,][vendor:[<vendor-class>],][<opt>|option:<opt-
name>|option6:<opt>|option6:<opt-name>],[<value>[,<value>]]
Specify different or extra options to DHCP clients. By default, dnsmasq sends some standard options to DHCP clients, the
netmask and broadcast address are set to the same as the host running dnsmasq, and the DNS server and default route are
set to the address of the machine running dnsmasq. (Equivalent rules apply for IPv6.) If the domain name option has been
set, that is sent. This configuration allows these defaults to be overridden, or other options specified. The option, to
be sent may be given as a decimal number or as "option:<option-name>" The option numbers are specified in RFC2132 and sub‐
sequent RFCs. The set of option-names known by dnsmasq can be discovered by running "dnsmasq --help dhcp". For example,
to set the default route option to 192.168.4.4, do --dhcp-option=3,192.168.4.4 or --dhcp-option = option:router,
192.168.4.4 and to set the time-server address to 192.168.0.4, do --dhcp-option = 42,192.168.0.4 or --dhcp-option =
option:ntp-server, 192.168.0.4 The special address 0.0.0.0 is taken to mean "the address of the machine running dnsmasq".
$ dnsmasq --help dhcp
Known DHCP options:
1 netmask
2 time-offset
3 router
6 dns-server
echo 'dhcp-option=option:netmask,<PUT_YOUR_SUBNETMASK_HERE>' | sudo tee /etc/dnsmasq.d/11-pihole-dhcp-subnet.conf
sudo service dnsmasq restart
Hi
Thanks for the pointer, understanding that dnsmasq is what underpins Pi_Hole was the main stumbling block, very noob!
Then finding this was key - dnsmasq(8) — dnsmasq-base — Debian stretch — Debian Manpages
dnsmasq takes the default gateway from the ifconfig and it was wrong there so have fixed that instead.
