Hello Everyone,
Just a question related to the usage of a docker to setup PiHole.
Do you configure the PiHole docker in bridge or as a docker host ?
I'm currently fighting with the fact that I only see one client (172.17.0.x)
Any solution to provide ?
Thanks
Sorry, I'm not sure how to do that. You can't execute commands like with docker run in the docker-compose.yml. You could probably hard code unbound's IP address, however, and isolate it in its own network. Not ideal.
See my message above Pi-hole to Unbound forwarding fails - #4 by musicsnob . What do your docker run commands look like?
I’m used a basic tutorial for Synology
Install the docker, with a pihole image on it
Following this
I've moved this to the Synology forum and updated the title to hopefully get some more exposure for you.
thanks a lot
I'm checking
Hi Dan,
the topic, I'm in here has been already moved, correct ?
system
Closed
August 13, 2019, 12:01pm
10
