How to change dns without using router interface
My wonderful internet providers do not enbaled the option of changing the dns of the router and i dind't founded a firmware for my router
my router ZTE (or ZXHN) F660)
btw i have no budget to buy another router if you're thinking that
Manually change DNS settings on clients?
It's a crappy way but doable in most cases...
In phones/tablets i can't do it when i change the dns it just dont connect to the wi-fi
And that's why i want pi-hole for use it in phones
Depending on device that "should" be possible by changing to static IP...
As said, it's somewhat crappy solution.
Disable DHCP on the router and use Pi-hole for DHCP.
i think i not even can disable dhcp from my router's admin interface
