Hello, since version 5 release i cant figure out how to add multpiple blocklists at once. The blocklist page shows you can use a coma between a link and another but it is not working for me.
In version 4 i used to add them from the command line editing the blocklist file but since version 5 the blocklist is a db file and i dont know how to manually edit it
They are not separated by comma but by space.
The error you see indicates that you are trying to add an adlist that is already in your database.
This FAQ contains methods to insert blocklists:
