How I implemented parental controls
I think I'd share my approach for simple parental controls. Since the API does not support this yet my approach is script based.
I have a named group (NoGameNoTube). I have specific devices assigned to that group (I use DHCP reservations so there is no volatility). I have several domains (wildcards, regex, or plain) prohibited or allowed and assigned to the named group. I do not block everything for that group so that the devices still think they are online.
From a script I enable or disable the domain list. A crontab entry calls the script with the respective option. The list can also be dis- or enabled via the web interface.
#!/bin/bash
# call this script with 'scriptname school' or 'scriptname playtime'
# warning: you may break your database
if [[ "$1" == "school" ]]; then
    sudo sqlite3 /etc/pihole/gravity.db "update 'group' set 'enabled' = 1 where name = 'NoGameNoTube';"
    /usr/local/bin/pihole restartdns reload-lists >/dev/null
fi
if [[ "$1" == "playtime" ]]; then
    sudo sqlite3 /etc/pihole/gravity.db "update 'group' set 'enabled' = 0 where name = 'NoGameNoTube';"
fi
Note that any teenager with a bit of tech savvy will likely figure out how to bypass these restrictions. Use the cell service on their phone, use a VPN, manually change their DNS assignments, hop on the neighbor's wifi if open, use their friend's cell phone as a hotspot, etc.
That doesn't make this a bad script, it's just not foolproof for the intended purpose.
Yep, can confirm, the total block variant has been bypassed. The version where just some distracting sites are being blocked during remote learning sessions is holding up.
